Old 10-05-2009, 09:21 PM   #1
Todd Boyer
Liked 6 Times in 5 Posts
Default Question for Dodge Dart Stocker Racers
Considering building a '69 340 Dart Stocker and want to know what size rear wheel/tire combo can fit in the little rear wheelwells. Need wheel width and backspace numbers and tire diameter and width numbers. Also what wheel lip mods done if any. Will be running Calvert rear suspension. I'm assuming offset hangers or shackles aren't legal.
All help is greatly appreciated.
Thanks Much!!!
Todd
Old 10-06-2009, 01:33 PM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Question for Dodge Dart Stocker Racers
Todd,
I have a Volare Stocker (F body not an A body) and I just put a new set of Hole Shot wheels on it replacing the Welds it had. The rear wheel back spacing I used was 4 7/8" which gives me 5/8" clearance to the Calvert springs. The Welds that I replaced were 4 1/2" backspacing.This is with no wheel lip massaging and an stock width 8 3/4 rear. I'm not sure but I if the back spacing on the A body and the F body are the same but I have been told they are. Jim
Old 10-06-2009, 01:41 PM   #3
Sean Haning
Sean Haning's Avatar
Send a message via AIM to Sean Haning
Default Re: Question for Dodge Dart Stocker Racers
Originally Posted by Jim Wahl View Post
Todd,
This and no pics!?
Hired gun w/o gun.
Sean Haning is offline   Reply With Quote
Old 10-06-2009, 01:46 PM   #4
Jim Wahl
Jim Wahl's Avatar
Red face Re: Question for Dodge Dart Stocker Racers
I have pics but I don't know how to post them! Jim
Old 10-06-2009, 01:51 PM   #5
Sean Haning
I'd offer to post them but I've never done them before, lol.
Hired gun w/o gun.
Old 10-06-2009, 07:10 PM   #6
GTX JOHN
You can BARELY FIT 9.0 radial with some lip massage. Calvert makes a narrower rear monoleaf that make a big difference. Still no walk in the park!
Old 10-06-2009, 07:43 PM   #7
Todd Boyer
What width of wheel John? And with 4.5" backspace?
Old 10-06-2009, 08:23 PM   #8
Jim Wahl
Jim Wahl's Avatar
I forgot to state that mine is a 10 inch wheel with a 30.0 X 9.0 Hoosier radial - Lightweight. Jim
Old 10-07-2009, 12:06 AM   #9
Paul Wong
Liked 419 Times in 85 Posts
You are going to have to do your homework. I had to do everything to get a 9 x 30 radail under the car. As John said narrow leaf springs and a lot of massaging. I wouls also start with a 8.5 inch rim if you have not done a lot of work to the car.
Paul Wong is offline   Reply With Quote
Old 10-07-2009, 03:38 AM   #10
GTX JOHN
10" Rim with 4 and 7/8 or 5 back. 8.5 with 4.25 or 4.5 with small spacer if you must. Our Volare/Aspen combo has HUGE fenderwells by comparisions. Mopar makes a spring hanger that is .8" narrower that will bolt in A Body..... you might try that, it looks stock if you are good at rewelding spring hanger on housing but it probably is not legal but not very noticable.
