#11 |
Treessavoy. take a look at the edelbrock website and find me a combination that isn't covered. As for not making a head for every combo, look at what they did with the Big Block Chevy. They use one head to fit multiple combos by changing valve sizes and combustion chamber sizes. So your argument doesn't hold water.
#12 | |
Liked 4 Times in 4 Posts
Without looking .....1962/3 Max Wedge, 1964 Max Wedge so I'll just keep holding that water! JimR
Jim Rountree |
#13 |
After spending over $4000 to repair one head for a SBC 255 hp motor, I vote YES
Dick Kirkpatrick 3033 SS |
#14 |
Banned
#15 |
Banned
Liked 235 Times in 110 Posts
Someone needs to get Edelbrock to reproduce the Max Wedge heads and 383/440 heads ACCURATELY with the CORRECT valve size and C.C's in alum. (along with others) and get NHRA to approve them. Someone went out of their way to do the same for the 428 CJ Fords and 427 Ford FE Medium riser heads and NHRA deemed them legal replacements in STOCK and S/S in the past. The GM Alum head was made a legal replacement for STOCK and S/S even though the exhaust ports are wrong, the intake port is a cross between a square port and an oval port and they came with 11/32 stem valve guides which was a pain to make into 3/8 size. That material was hard as hell to cut or hone. I wont even mention the latest GM intake manifold for big blocks that was made a legal replacement with the plenum cut resembling the L88 intake (also known as the "Grumpy" modification.) So whats wrong with making it fair for the Mopar guys and the AMC, OLDS, BUICK, and Pontiac guys also? As far as you guys bitching about "rules changes" this has been going on for a LONG TIME for the Fords and GM big blocks.
#16 |
Liked 16 Times in 11 Posts
Terry the GM heads have a gm part # I dont know about the fords, if the fords dont then you mite have a case. Also the next question will be can he sell Max heads, or is the market big enough. NSS can run any head so that cuts into that count. I will email and see what kind of response I get.
Bob Pagano A/SA |
#17 |
Liked 64 Times in 14 Posts
Is NITROS next??
Come on keep it simple I know it isnt simple anymore but lets keep it as simple as it can be This idea isnt a good thig for SS...
Mark Callanan 1027 STK |
#18 |
What can be more simple than allowing Edelbrock aluminum replacement heads for all SS cars.
If that were proposed/allowed by n/ihra I am sure Edelbrock would be more than happy to produce the few cylinder heads that are not produced at the present time.
#19 | |
Banned
#20 |
Mark Callanan, let's not get dumb.Nobody is saying get away from the basic combination. I don't know if you own a SuperStocker, but with us being able to port and polish intake,exhaust ports, along with the combustion chambers what is the difference than the material the head is made from? Like I said before, sink close to 7500.00 into a good set of iron heads and see what it cost to fix it if one or both get hurt as compared to aluminum. I didn't say change carb,compression or any of the original combo. The aluminum heads usually come with the mods that we pay so much to the Head guys to perform.
