Old 10-09-2009, 06:18 PM   #1
Michael Kilduff
Default Quadrajet Question
Hello All,
I have the opportunity to get a 1974 quadrajet, part number 7044202...my question is this-is it a legal replacement for carb number 7029201? If it is then my next question will be is it a good choice as a replacement or is there something else that would be better? It appears as though the carbs are the same size according to the blueprints listed on NHRA.
Any adoce is appreciated!
Michael Kilduff
Michael Kilduff is offline   Reply With Quote
Old 10-09-2009, 08:41 PM   #2
Danny Ashley
Liked 110 Times in 29 Posts
Default Re: Quadrajet Question
Yes, this Q-Jet is a legal replacement since both have a venturi size of 1.093 inches. In the world of Quadrajets, in my opinion, there isn't one particular number that is better than another. You just have to build one and try it and then if you can, compare it with others. The truth is that you are at the mercy of the core. Some are just better that others and the only way to find out is to try it on the car. One word of caution, DO NOT believe dyno figures when it comes to Quadrajets! The one that makes the most HP may not produce the quickest E.T. Dynos don't move or shift gears. Hope this helps. Danny
Danny Ashley is offline   Reply With Quote
Old 10-10-2009, 12:15 AM   #3
Bruce Fulper
Liked 54 Times in 33 Posts
Mr Ashley - would you please give me a call at your convenience. 909-844-1081
After 9 am West coast time.
Thank you.
Bruce Fulper is offline   Reply With Quote
Old 10-10-2009, 07:45 AM   #4
terry1
Liked 24 Times in 13 Posts
Cool Re: Quadrajet Question
I always thought that the carb # had to match the # on the blue print sheet for that particular engine combo.
terry1 is offline   Reply With Quote
Old 10-10-2009, 08:07 AM   #5
Randy Schonscheck
Liked 2 Times in 2 Posts
That's pretty much been changed. The only thng that matters is the venturi size. You can have either the front or side fuel entry too.
Randy Schonscheck is offline   Reply With Quote
Old 10-10-2009, 06:08 PM   #6
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
That is very ture................found out the hard way........
Bob Bender 144 O/SA
