Old 10-11-2009, 09:08 AM   #1
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default Stroke measurement
I have a feeling this is a stupid question, but I can't seem to figure it out on my own so here goes....how does NHRA measure stroke in teardown? I'm disassembling and measuring the "used but freshened" 327 I bought for my Nova and haven't seen a dial indicator that goes that far. Also, the spec sheets say .002 in the hole and .018 head gasket...sounds a little tight to me. I realize that's a minimum, but how close is too close?
Paul Merolla is offline   Reply With Quote
Old 10-11-2009, 09:34 AM   #2
Paul Merolla
Default Re: Stroke measurement
Duh...just answered it for myself: http://www.jegs.com/i/Lunati/638/98900/10002/-1
Kinda pricey, though. Is there a way to do it without that tool?
Old 10-11-2009, 09:39 AM   #3
BlueOval Ralph
Banned
That is used when crank is out of block, PMS make a tool to check from the deck with crank in block.
Ralph
BlueOval Ralph is offline   Reply With Quote
Old 10-11-2009, 02:28 PM   #4
Rory McNeil
Pretty sure when I tore down before that they just used a 6" caliper.
NHRA 6390 STK
M/S 85 Mustang
Old 10-12-2009, 12:02 AM   #5
Tom Meyer
Liked 354 Times in 120 Posts
Been torn down about 20 times, they use a caliper in TDC indicater. Rock it on the bottom of the stroke set to zero then rotate it up you will then have your stroke. They check deck hieght plus gasket as long as you are more than the spec you are ok, I run about 35 on my 283 you may want a little more on the 327. Tom
Tom Meyer 5240 SS Stock ???
Old 10-12-2009, 04:57 AM   #6
RJ
6" caliper
RJ is offline   Reply With Quote
Old 10-12-2009, 08:41 AM   #7
Paul Merolla
Thanks Tom - did you figure out why you kept blowing the tires off?
