I understand that NHRA factors SS cars off of " Factory Shipping Weight" plus 170lbs for driver can someone tell me what factory shipping weight would be for a 1971 Plymouth Duster 340 auto??
Liked 333 Times in 180 Posts
how about 3140 pounds--comp 387
NHRA says 3154
OK-- comp387
so, 3140 +170 for driver = 3310lbs/340 cid = 9.73 lbs per cubic in ????
shipping weight 3154, factored hp 283. 11.14 factor, only add the 170 after to figure your minimun weight.
SS/IA=3000lbs min SS/JA= 3280lbs min SS/KA= 3565lbs min i think they round down in SS weights correct me if i'm wrong.
Dusty Lowell #1773 STK F/SA |
I still have the original factory paperwork on my 1971, 340 auto, Demon. It says 3165lbs. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Do i need to weigh by actual scale weight what the class weight is or is that just a number that they use to class the cars ????I'm going to be adding some weight to the front of and already nose heavy car ( 56%-44%) by removing my fibergalss hood and going to a steel hood So if I know where I need to weigh maybe I can add some weight in diffrent places to make up the imbalance. Thank you guys for all your help and imput just trying to figure out where I need to be..
you can basically weigh anything you want as long as its heavier then the minimum. In some divisions if your heavier then the next class minimum they will give you some *****. ie: running SS/JA at more then the SS/KA minimum weight. So it doesnt matter where the weight is just how much total. Although it definately matters in the setup where your weight is i'd say 50/50 is ideal for a stocker, not sure in a SS.
Your combo is a natural "J" car which is an 11lb. class. You are allowed to weigh the minimum for the class. You are also allowed to move up one class (SS/IA) or down one class (SS/KA. To run your natural class (SS/JA) your car must weigh 3280lbs. 11lb class X 283hp + 170lbs = 3283 rounded to 3280lbs. Jim
