Old 10-12-2009, 03:34 PM   #1
69camz28
Default ET difference w/ less oil
I was curious what type of ET gains can be seen from running with 3 quarts of oil vs 5....Anyone willing to share any gains?
69camz28 is offline   Reply With Quote
Old 10-12-2009, 08:00 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: ET difference w/ less oil
You'll go real fast just before you blow it up! I had what I thought was a "minor" oil consumption problem in my AMX Stocker. The engine was sealed so no dip-stick. And I was lazy. I ran 3 10.500's in a row in D/S weight while local bracket racing. Then I put a rod through the pan. No oil on the track. I took it home, drained the oil. The filter had it's oil and there was about a 3/4 of a quart in the pan.
Normally under great conditions and 5 qts of oil in the pan it would go 10.55 to 10.60. So call it .08 for danger zone oil levels. After that I placed a 1" sight glass in the pan.
Jeff Lee 7494 D/S '70 AMX
Old 10-13-2009, 01:25 PM   #3
Ed Wright
Ed Wright's Avatar
I hear of people doing that. I'm not that brave.
Ed Wright 4156 SS/JA
Old 10-13-2009, 05:06 PM   #4
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
now that an accusump is legal,wouldn't that take care of the issue?
Old 10-13-2009, 06:00 PM   #5
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
the accusump is there for protection against oil not being at the pick up tube for insurance only ,,i wouldnt make a habit running low oil to gain a few hundreth's or tenth,,engines a way to expensive to be blowing up ,,,,i would run a light oil and keep the engine cool before the pass (less than a hunderd degrees)
gmonde
Old 10-13-2009, 06:33 PM   #6
Mark Callanan
Liked 64 Times in 14 Posts
gmonde
You run a run with less then 100 water temp?
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 10-13-2009, 06:48 PM   #7
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Man! I can't even get to the burnout box under 140 degrees! lol This car doesn't mind the temp, though, particularly with the M1 manifold.
I run CAM2 Blue Blood Racing Oil, 0w30, full-time, even bracket racing, double-entered, hot-lap, you name it. Won 3 out of 4 days at the Div. 2 Bracket Finals this weekend. I find the thinner oil to be more consistent over the course of the day. You can get it right off their website if you're interested.
While I've never run one near as low as Jeff, I know what he's talking about. There's a few hundredths to be gained, but in emergencies only. I run typically run 6qt, but the current setup uses oil. I change it a lot more frequently than my bracket car just because it doesn't have a dipstick.
Old 10-13-2009, 07:38 PM   #8
gmonde
gmonde's Avatar
once the engine is warmed up in the beginning of the day i cool it till the needle sits on the peg,,,start it and coast it up to the staging lanes,,,try to stage at the coolest temp (140 is the normal temp as the tree drops) 160 at the end 1320,,,,,the cooler the better gmonde
Old 10-14-2009, 05:48 AM   #9
Dusty Lowell
Dusty Lowell's Avatar
Send a message via AIM to Dusty Lowell
Wink Re: ET difference w/ less oil
i'd say ice and less oil is worth probably .15-.20 for us on a hot day not so much in this cold weather. ie 50-60 degrees. maybe a tenth at best. I guess it all matters on how much oil you run on the regular, lol.
Dusty Lowell
#1773 STK F/SA
Dusty Lowell is offline   Reply With Quote
Old 10-14-2009, 06:27 AM   #10
buzzinhalfdozen
Liked 11 Times in 8 Posts
Unless you're running a stock type oil pan I see no reason to believe there would be an E.T. gain by draining oil from the engine.Basically the only thing you're doing is reducing windage in the crankcase. With a properly designed pan, scraper and if possible windage tray draining oil is only going to hasten the death of your engine. I would opt for some of the ultra low viscosity oils instead, at least you would have a steady supply of lube to the bearings, although it does have the consistency of water, some lube is better than no lube. As far as running the engine "cold" I do that. After fully warming the engine I leave the water pump and fan on till the water temp is ambient, seems to be a little faster, of course you need a pretty effecient cooling system to accomplish this in later rounds. Joe
Joe Buchanan SS/BX 3117
