What head gaskets would you sugest for a 0.030" over 305, I dont want to run the stock 0.041" thick gaskets I want to be around 0.026- 0.020" thick compressed. The only ones I can find are from GM performance, just wondering if anyone else has a line or a lead on some different brands I could look into.
Thank you before hand. Cam
It's only a 305 305 0.030" over, 12:1 comp, 461 casting heads, 1.90" in & 1.50" ex, Comp Cams XE284H, [SIGPIC][/SIGPIC] |
Liked 19 Times in 4 Posts
Try Cometic... a bit more money but available in any specified thickness..., they are also reusable, a bonus considering the price!!!!
good luck fellow Canuck!!! later ![]()
TURKMAN 4002 Stock, 4002 Super Stock |
#3 | |
Thank you I will try them any key words or a link I can try to make it a little quicker
Ah, cometic.com
toll free 1-800- 752-9850 440-354-0777 they are out of OHIO
thanks again
Anyone else have a source other than GM perf as cometic does not carry anything under a 4.100" bore gasket. The 305's require somewhere in the 3.800" range bore on the gasket, if I go too big I am going to loose comp. and sealing capabilities and maybe the chance of heat soaking the spark plug cooling jackets.
#7 | |
Liked 510 Times in 117 Posts
68 Chevy11 327 F/S |
Yes, Cometic makes all sizes. Most don't stock the small b ore stuff, but they make any size. We have 283 stuff made. Here are the thicknesses. If you need a contact at Cometic, let me know. Jim
.027 .030 .036 .040 .045 .051 .056 .060 .066 .070 .075 .080 .084 .086 .089 .092 .095 .098 .120 .140
James Schaechter 3163 STK |
Just ordered a pair 2 weeks ago for the camaro. It took about 5 day to get. You give them the bore and thickness and they custom make them. They were about 90 dollars a gasket but they reuseable. Call them they will take care of you.
Corteco sells ones that are .028 thick crushed in there performance line for a 305.
