Old 10-23-2009, 12:44 PM   #11
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Pulley size is now a spec
Hate.....thats another story but its tough enough dealing with fuel injected cars in the same class but SUPERCHARGED should be in a class by its self just like AFX was. NHRA has a can of worms on their hands and no one in those classes have a chance against them least they break or red light.
Bob Pagano A/SA
Old 10-23-2009, 12:50 PM   #12
Chad Rhodes
Originally Posted by Bill Grubbs View Post
Chad,
The pulley spec has always been there, just not published. However, I do not know if they were checking them.
Bill
Back at the beginning of the year I asked an NHRA divisional tech guy if they had a spec for it, and i was told that Glendora may, but they did not have it in the field. Obviously i have know way of verifying this.
Chad Rhodes 2113 I/SA
Old 10-23-2009, 03:24 PM   #13
Tim Kish
Liked 11 Times in 4 Posts
Originally Posted by Chad Rhodes View Post
the OEM tensioner is spring loaded. Metco and others make tensioners that are positive acting, and act on a different place on the belt thus increasing boost by eliminating any slippage. The tensioner should at minimum have to be of OEM type (spring loaded) and should be in the stock location
Are you running OEM valve spring seat pressure? Becuase if you are allowed to change your valve springs to prevent valve float you'll make more power and we can't have that.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 10-23-2009, 04:05 PM   #14
Chad Rhodes
apples and oranges
if the factory tensioner is spring loaded, so should whatever tensioner that is on it. otherwise its kinda like putting solid roller lifters on a hyd roller cam
Old 10-23-2009, 05:25 PM   #15
Tim Kish
apples and oranges
But you first said the requirement should be the OEM tensioner be required. Now you say it should be a spring type tensioner if OEM is a spring type - this is a more rational request.
Tim Kish
3032 SS/GS
Old 10-23-2009, 05:30 PM   #16
davidhuff
Liked 120 Times in 42 Posts
Ford Racing knew the stock supercharger pulley on the cobra jet was going to be a issue and this is what they are going to do:
2007 cobra jet has a 2.3L eaton supercharger
2010 cobra jet has a 3.4L whipple supercharger and this supercharger is bad *** and will move a ton of air!
Old 10-23-2009, 05:32 PM   #17
Tim Kish
That is debatable!
Tim Kish
3032 SS/GS
Old 10-23-2009, 05:50 PM   #18
davidhuff
That is debatable!
I have a 2007 shelbygt500 street car and just removed the 2.3L ford racing tvs supercharger and replaced it with a 3.4L whipple supercharger and 64mm whipple throttle body.Take my word,this supercharger is bad ***!
Old 10-26-2009, 07:46 AM   #19
Tim Kish
My point Dave is along the lines that you increased the supercharger size almost 50% - did you increase HP by 50%? Don't think so. The Whipple screws are not as efficient as the TVS, they have to be much larger to realize the airflow and HP increases like you have seen.
Tim Kish
3032 SS/GS
Old 10-26-2009, 08:19 AM   #20
Bob Pagano
Bob Pagano's Avatar
The 2010 CJ will be SS Only
Bob Pagano A/SA
