Old 10-24-2009, 09:22 PM   #21
rayfin
Default Re: ET difference w/ less oil
I thought Grumpy Jenkins always said a hot engine builds more HP?
rayfin is offline   Reply With Quote
Old 10-25-2009, 06:42 AM   #22
Billy Nees
In an "ideal" situation you would want the shortblock and the combustion chambers hot and icicles hanging on the intake!
Billy Nees 1188 STK, SS
Old 10-25-2009, 11:36 AM   #23
Jeff Lee
Jeff Lee's Avatar
I think when Grumpy was quoted oil was typically on the 20-50w range for race engines.
Now 0w is not uncommon.
Jeff Lee 7494 D/S '70 AMX
Old 10-27-2009, 08:22 AM   #24
Ed Wright
Ed Wright's Avatar
They were cooling his Pro Stock stuff down a couple of years ago just like everybody else. When that book came out everybody I know that tried it slowed down. He said he had a switch on his shifter that turned the water pump on in 2nd gear. We all went back to cooling them down. The all aluminium engines don't seem to care, and many actually like to run above 180 F. The LS1 is a great bracket engine because it makes the same power between 180 and about 210. I cool mine with a seperate battery to run the water pump and fans. Like Jeff mentioned, we often take it to the staging lanes to cool down for heads-up races.
Ed Wright 4156 SS/JA
Old 11-01-2009, 02:27 PM   #25
trmnatr
How many of you guys have drained the water in the pits between rounds and added COOL fresh water to cool the engine better
On all of our stuff filled with Hardblok the water cools down alot quicker. The oil temp will run a little hotter but we have no problems from Hardblok
trmnatr is offline   Reply With Quote
Old 11-03-2009, 01:52 PM   #26
tim worner
Liked 126 Times in 20 Posts
I can tell you first hand that 10 qts over 5 will slow you down 3 tenths and almost 4 mph, Did it ,by accident, @ Indy a couple years back.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 11-03-2009, 02:52 PM   #27
Greg Barsamian
Liked 427 Times in 97 Posts
Originally Posted by Bub Whitaker View Post
Carefull Dusty...
Kidz...............
Greg Barsamian is online now   Reply With Quote
Old 11-07-2009, 08:20 PM   #28
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Originally Posted by Greg Barsamian View Post
Kidz...............
KIDZ, what do they know anyway!!! Still WET 6qts, back down da timing, and turn up da HEAT, works for me!!!
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
