Old 11-06-2009, 02:24 PM   #11
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: TH350 Front Pump
Chad, unless your trans is set up to operate on the lower volume pump I'd steer clear of it . Less fluid volume may result in undesireable operation, not worth the risk unless you're looking for every possible amount of power. If that were the case I'd assume you would have a purpose built trans already equipped with the low volume pump I've never seen H.P. figures in print but have been told as much as 6-8 H.P. with the low volume pumps. Joe
Joe Buchanan SS/BX 3117
