Old 11-19-2009, 09:40 AM   #11
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: E.T. loss ?
When you changed jets did E.T. change? If it didn't pull rockers& intake put air straight (no regulator) to
cylinders check for air leaking through intake valves if can't feel air, spray soapy water look for bubbles.
DON'T WASTE YOUR'RE TIME WITH LEAKDOWN TEST OR COMPRESSION TEST the leak I'm talking about is so small a leakdown or compression test will not show it. I'm not saying this is your problem but I've seen this many times. One almost positive sign of this is jet changes will not make hardly any difference and car will be inconsistent . Have you broke any valvetrain or broke driveline and hit rev limiter hard?
Mike Taylor 3601
Old 11-19-2009, 12:22 PM   #12
Jim Kaekel
Liked 535 Times in 110 Posts
Greg: Something also you might want to check is the balancer, if you are using a stock one. I got tripped up by this many years ago. Outer ring slipped on hub, thereby showing incorrect ignition timing. Very easy to check.
Jim Kaekel 3836 STK
Old 11-19-2009, 03:14 PM   #13
brett3533
brett3533's Avatar
Liked 47 Times in 14 Posts
Greg be sure to check battery and alt you may have a bad cell or shorted battery. Be sure the alt is not stuck on full charge causing power loss have seen regulaters stick, also have you noticed battery needs charged more often. Have you done any welding on car which could have caused diodes in alt to go bad. When you changed jets did plugs get darker or stay white. also check all ground wires ect may have a wire that vibrated loose after put engine in and at track few times. Have you changed fuel system, I have seen a few, fuel cells mounted real high in trunk and lets fuel siphon thru carb while sets in garage and causes rings to loose seal. sorry to keep rambling on but could be anyhting. All posts on here are possibilities.
Brett McFarland
A/S
brett3533 is offline   Reply With Quote
Old 11-19-2009, 05:47 PM   #14
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: E.T. loss ?
Here's the best I can tell you as dad has the log book with him ( logs every pass no matter who is driving). this is a 1bbl carb running holley style jets... with an 82 in it the car ran hott real fast i mean 200 right after a pass ( to lean) with 89 in it the car you could see a trace of smoke coming out of the car as it staged. the 85 seemed the best so that's what was in it last weekend. Now then fuel system has been in the car for 3 years. the cyl head is fresh. the balancer is a maybe as it is stock. Thing is we didn't move the timing...the car right out of the box ran 9.50's now then it's running 9.70's (1/8) the last passes I made with the car were a 9.71 we then changed tires & it went 9.73 I then went up & tried to "flat foot" the car & it went 9.70. i then went up for the "dial n 4 dollars" & it ran a 9.709 on a 9.70 then 1st round it went 9.712...so it's running ok just slow? dad dose think it may be in the rings...don't know but we got rings in for the "good" motor so he's going to put it back together for the spring....that engine will run some 9.30's. THANKS for all the help...we're going to try it again this weekend & see if we can find anything....mean while we changed header this week....so who knows!
Old 11-21-2009, 08:52 PM   #15
greg fulk
greg fulk's Avatar
Update! well we figured it out! (i guess) 2nd round about 30' off the line it went BANG!!!!! took the pinion right out of it! guess it's been going out for a few weeks? ya know it's not good when we pushed the car up on the trailer with the shifter in park!
Old 11-22-2009, 08:38 PM   #16
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Glad to hear you found something..... good luck to you.
