Old 11-20-2009, 09:39 AM   #11
JimNolan
Default Re: Stock or Super Stock
Dago,
I just got through reading about the NSS and NMC. That sounds interesting and my car qualifies for either of those classes along with Bracket. At least there's 7 of the last 9 events that are close to home. Jim
JimNolan is offline   Reply With Quote
Old 11-20-2009, 10:49 AM   #12
Bill Harris
Liked 26 Times in 13 Posts
Hey Jim, didn't mean to scare you off, just letting you know that the car does fit into several stock classes and has potential, but not for free.
If you want to keep it close to stock then there isn't any reason you couldn't run it as a 390/300 factored to 280 by the NHRA. It wouldn't take a ton of work to do that since you have the stock engine and (hopefully) carb. M/SA index is only 13.15 and you could probably get it to run that and better without spending a fortune.
The car has a leaf spring rear suspension with a 9" which is great and all you would need is a set of springs, shocks and bars from Calvert. 9" slicks would probably fit just fine in the wheelwells with the right offset wheel. You'd need a steep gear and a locker or spool and good axles, especially since min weight in M at 280HP is 4090 Lbs with you in the car.
Don't know what the front suspension looks like on these things but a set of lightweight wheels and tires and some loose shocks would get you started.
You could have the short block professionally rebuilt with the stock rods and a set of CP pistons and get Bullet to grind you an appropriate stocker cam. Have Blair Patrick do the heads.
The car probably has a Ford-o-matic trans which would need to be replaced with a prepped C4 and the appropriate converter, but that is easy.
It would be a cool car and with some work it might be quite competitive in class. Depending on what the car really weighs in race trim you might want to run L/SA instead with a 13.00 index and a min race weight of 3950 lbs.
If you set it up to run NHRA and IHRA stock class, you could still run the NSS an NMC events.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 11-20-2009, 11:49 AM   #13
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
From the 2006 PA Dutch Classic:
155 1390 K/S Craig Jernigan, Lewisburg PA, '63 Galaxie 12.647 12.85 -0.203
He was at my S/SS race in Maryland two weeks ago. When the pictures come back, I will post a few on here of the car.
Old 11-20-2009, 05:19 PM   #14
Dago Red
Originally Posted by JimNolan View Post
Dago,
Sorry to disappoint you Jim, but the only thing NASCAR does for me is make me nauseous.
I took a year and went to as many NHRA/IHRA races as I could swing as well as any NSS/NMC style events I could find. I just wasn't up for the challenge and dedication required to run a class car, but liked the mild to wild parameters in NSS.
Name:	Texas Thunder Ford.jpg
Dago Red is offline   Reply With Quote
Old 11-20-2009, 06:55 PM   #15
JimNolan
Guys,
I'm the biggest skeptic in the world, I've lived too long to believe anything anymore but I got the surprise of my life. The 63 Galaxie arrived this morning. This car was not undercoated and lived in New Mexico all it's life. It's perfect. Not a spec of surface rust other than the rear spings. I laid under it for an hour today just looking for rust. I could have wept with happiness. This is the third car I've bought off ebay and this is the only one that ended up being what the guy said it was. Everythings original, carb, dist, heads, Cruise O Matic etc. And to top it off it's got a new radiator and interior. Now all I have to do is throw 20K at it and I'll have a car to go racing with. Jim
