Old 11-22-2009, 06:19 PM   #1
FED 387
Liked 333 Times in 180 Posts
Question Trailer wiring ???
Bought a used enclosed trailer---all the lights work HOWEVER when you turn on the flashers or turn signals not only do the taillights work on the trailer although not real brite BUT the clearance lights on the trailer all flash and the Stop lite on the cab flashes too---BOTH turn lites on the truck flash but depending whether you are signaling left or right whichever way you signal that lite will be brighter than the other taillite but both are flashing---Disconnect the trailer and the truck is OK--put a new 7 prong plug on the trailer cuz the old one was a little scuzzy that did not help--- The guy I bought the trailler from had just installed ALL NEW Led clearance lites and 2 NEW regular (not LED)stop/turn lites---Anybody got any ideas??? I think I have a pinched wire some where but do not want to tear the whole interior out to find it---He also put new wood on the ramp door but I have no idea if he rewired it while he had that open- Suggestions gratefully accepted--Thanx Comp 387
Old 11-22-2009, 06:34 PM   #2
art leong
Default Re: Trailer wiring ???
I had a problem similar to that. They had one of the brake lights wired to the running lights.
When you put on the lights the brakes locked up.
Trailer wiring on trailers built up north can be a real problem to get to, because they are all enclosed.
Art Leong 2095 SS
Old 11-22-2009, 06:38 PM   #3
krugracing12
Add a ground wire from the truck frame to the trailer frame and the trailer frame to rear door frame. We have several older haulmarks that had the same problem and that cured it.
Bill
krugracing12 is offline   Reply With Quote
Old 11-22-2009, 07:16 PM   #4
FED 387
Question Re: Trailer wiring ???
OK guys Thanx will look into both ideas---anybody else got any more ideas??? Thanx FED387
Old 11-22-2009, 08:36 PM   #5
Wayne Ewing
Sounds to me like you could have a bad ground and some wires crossed up in your plug. Had some of the same problems on my Goldrush this summer and spent 2 days trying to figure it out. Are your trailer wires color coded? If I remember corectly the yellow is left turn, the green is right turn the black is taillights, the white is ground the brown is running lights, the red is to charge the trailer battery and the blue is the trailer lbrakes. The ground wire (white) has to go into the center post of the plug. Hope this helps some.
Wayne Ewing is offline   Reply With Quote
Old 11-22-2009, 08:46 PM   #6
FED 387
Wayne just double checked the wiring on the PLUG---the colored wires are where they are supposed to be---the center wire position on the trailer plug has no wire attached to it --never did days its for backup lites-no wire in the harness is available to attach to it---I do not understand how you run a ground wire from the truck to the trailer when I think going thru the hitch ball would work but if that is not the case how do you ground the trailer to the truck or the trailer door to the trailer frame???( hinges on the trailer door metal on metal not a good enough ground???)---I'm game talk to me this is exasperating spent all day Sun futzing with this bout ready to completely rewire the frigging trailer get it over with BUT I dont wanna do that hafta pull the ceiling down etc.--- Keep those ideas coming ---Comp 387
Old 11-22-2009, 11:58 PM   #7
Michael Pliska
Just try temporarily hooking a jumper cable from the truck frame to the trailer frame, to see if grounding is the issue.
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 11-23-2009, 12:39 AM   #8
GTX JOHN
Liked 2,485 Times in 697 Posts
I agree... sounds like a ground wire problem for sure. The LEDS
are not as fussy as conventional bulbs. When the ground is bad my trailer do a lot of backfeeding and funny stuff.
Old 11-23-2009, 12:40 AM   #9
Shawn Blair
Shawn Blair's Avatar
It's more than likely a grounding issue from truck to trailer. This has happened to me before, but as soon as i started driving the ball and hitch made a good ground and it worked fine. Good luck!
Shawn
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 11-23-2009, 08:27 AM   #10
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Make sure that your brake light bulbs are indexed properly. I have seen where it is possible to install the bulbs 180 degrees out and cause this condition.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
