Old 11-24-2009, 12:58 PM   #1
John Kelley
Default Fuel Tester
Where can you buy a fuel tester like NHRA uses for gasoline ?
John Kelley is offline   Reply With Quote
Old 11-24-2009, 01:43 PM   #2
FED 387
Liked 335 Times in 182 Posts
Exclamation Re: Fuel Tester
760-375-2398-phone
ridgecrest.ca.us--website
Precision Fuel Testing Systems---company
Model FT-K01----part number
ONE THOUSAND BUCKS $$$$$$$$$$$$$$ plus any accessories
make sure you test on a NON metal counter and not within 12 inches of metal walls counters etc-----polypropolene container only !!!! probe fully immersed!!! rock probe back and forth to remove any air bubbles in probe!!!!!! FAILURE to do any of the above will give you a false reading
Old 11-24-2009, 07:41 PM   #3
John Kelley
Default Re: Fuel Tester
Thanks for the info !!
I didn't think it'd be cheap.........BUT WOW !!
http://www.ridgenet.net/~hideseng/g-01.htm
Old 11-24-2009, 08:11 PM   #4
David Ley
David Ley's Avatar
Send a message via AIM to David Ley
Don't forget you will also need some Cyclohexane to go with the tester.
Dave Ley
NHRA TECH
David Ley is offline   Reply With Quote
Old 11-24-2009, 11:09 PM   #5
John Kelley
They have that also....
GASOLINE TEST KIT:
Designed for the competitor who wants to assure the legality of his gasoline, this kit provides a sturdy carrying case for your fuel tester with all the items needed to test your own gasoline. The Gasoline Test Kit includes:
• Fuel Test Stand
• 150ml sample cups (4)
• 500 ml DoT bottle for cyclohexane sample
• Fuel siphon.
• Safety Items, includes glasses & gloves.
• Elegant aluminum carrying case which houses and protects all of the above items and the fuel tester.
Old 11-25-2009, 09:28 AM   #6
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
How would you know its calibrated correctly? I have been in the fuel trailer when the tech guy comes in there "setting" the meter. Is this an every race day or weekend occurance? If the fuel companies' specs are the same every time, why recal the meter?
Wade
Old 11-25-2009, 12:27 PM   #7
John Kelley
I believe the cyclohexene is used for calibration.......from what I read.
Old 11-25-2009, 01:23 PM   #8
Rory McNeil
And don`t forget that you would also need the specs for the fuel being tested, as well as temperature conversion chart that shows the different readings for a given temp.
NHRA 6390 STK
M/S 85 Mustang
Old 11-25-2009, 01:56 PM   #9
Nitro Joe Jackson
Nitro Joe Jackson's Avatar
Liked 67 Times in 19 Posts
my friend that i do the Mopars at the Strip event has a brand new tester only used once and its the same one NHRA uses, if interested, e-mail me and I'll give you him e-mail and phone number. I might bring it home with me in march after the race to try to sell it around here for him.
He has the Cyclohexane to go with it also
Nitro Joe Jackson STK 3431
nitrojoe@neo.rr.com
