Old 11-23-2009, 11:17 PM   #11
Dave Casey
Liked 804 Times in 168 Posts
Default Re: Compression ratio calculators??
13.54 to 1
I look at as the volume with the piston at bdc divided by the volume with the piston at tdc
convert all values to cc's is easiest for me
16.387 cc's per cu inch
bore and stroke volume + deck volume + chamber volume +gasket volume-dome volume
divided by
deck volume + gasket volume + chamber volume - dome volume
Dave Casey 1330 STK
Old 11-23-2009, 11:27 PM   #12
art leong
Originally Posted by Dave Casey View Post
13.54 to 1
divided by
Thats the way i thought it was calculated. But why are the calculators on line so far off? It seems like simple math to me. I just wasn't sure of the formula.
Art Leong 2095 SS
Old 11-25-2009, 09:08 AM   #13
Adger Smith
Liked 880 Times in 311 Posts
In doing a little number movement with most of the on line calculators I think they are not figuring the dome vol. + or - properly in the formulas.
Art,
Daves formula was the one I had at the shop that I said I would PM to you.
Adger Smith (Former SS)
Old 11-25-2009, 01:09 PM   #14
NORMAN BARNARD
Liked 2 Times in 2 Posts
Mine also converts everything to cc's so i can do a "pour check" with a burette thru the spark plug hole as a double check before the motor is sealed. At least we've found some consistency in a couple of programs.... Everybody have a good thanksgiving.
NORMAN BARNARD is offline   Reply With Quote
Old 12-01-2009, 09:19 AM   #15
Chris Hardy
Guest
Posts: n/a
I have a compression ratio calculator on my website that seems to be very accurate. www.racingenginetechnologies.com/services
Please let me know what you think.
Thanks,
Chris Hardy
Old 12-01-2009, 01:03 PM   #16
Dave Gantz
Liked 251 Times in 125 Posts
A couple of the ones that I tried consider piston dome as a positve number, some consider it a negative number.
Old 12-01-2009, 01:46 PM   #17
art leong
Yes but even when entered correctly they vary by a lot. The one thing I have figured out is my new motor has about 1 more in the compression ratio.
Art Leong 2095 SS
