Old 12-02-2009, 02:00 PM   #1
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default carb ?
you can a 73 carb on 72 motor, but can you 72carb on a 73 motor? its in a 340 dodge.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 12-02-2009, 02:10 PM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: carb ?
Kelly, Basically, as long as the carb is the same make and model and CFM and as long as the fuel inlet is in the same place the answer is yes. In your case they are interchangeable. The '71, #6138 really is a better choice than either the '72 or the '73 carbs. (Thermoquads are my thing). Check the "Blueprint" section @ NHRA.com Jim
Old 12-02-2009, 02:41 PM   #3
dartman
dartman's Avatar
Default Re: carb ?
Thank you for the info.i think i have a 4973 71 340 around.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
Old 12-02-2009, 02:48 PM   #4
Jim Wahl
Jim Wahl's Avatar
The 6139 works well also. Jim
