Was wondering what was involved in changing out the 700R4 for a Turbo 350.
Is the trans a different length? Will the driveshaft need to be lengthened/shortened? Is trans mount in same location? Can the original crossmember be used and in the same location? How about the tunnel, any problems there?
Bobby & Norene Zlatkin L/SA |
Liked 1,863 Times in 422 Posts
A TH 350 is shorter than a 700 R4, and the mount is closer to the front. No, the original crossmember cannot remain in the same location. No problems with the tunnel. If you can find a car that was built with a 200 Metric, the crossmember, mount, driveshaft, and torque arm mount are where you need them. You will have a very hard time finding a TH 350 extension housing with the mounting holes and mounting bosses for the torque arm brackets.
Alan Roehrich 212A G/S |
Liked 12 Times in 4 Posts
B&M makes a reasonably priced and simply bracket for the torque arm. Part No. 30299. Use the stock driveshaft for 1982 Camaro with TH200.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
You can get on www.LS1tech.com there are guys over there that are putting th400 and 4l80 into these cars.
Next time wave all of your fingers at me. |
