Old 12-08-2009, 08:29 PM   #11
Marc Kinton
Default Re: Turbo Stockers
Originally Posted by Jimi B View Post
With the stock turbos that shouldnt be a problem! Getting the boost the same every pass to actually win a round is the real challenge!
Guys, if ya don't mind I would like to join in on this conversation. I have just started running an '88 thunderbird 4 cylinder turbo car and would love to ask some questions. I'm an IHRA car in I/FIA but could fit in H/I/J with weight.
1.) Assuming you are using a two-step, what rpm are you able to leave at?
2.) How much difference, if any, have you noticed with engine temperature being higher or lower in your et's?
3.) How in the heck do we figure out how to dial these things? I have noticed if we are running pretty close my car seems to fall off .05-.10 every pass. Is that pretty normal?
Thanks for any help
People tell me to just put a small block in it and forget this turbo stuff. But, I do like a challenge!
Marc Kinton is offline   Reply With Quote
Old 12-09-2009, 09:26 AM   #12
art leong
Thanks for any help
Sounds like your having an electronics issue. You can not fight the computer, you have to fool it
Art Leong 2095 SS
Old 12-09-2009, 09:52 AM   #13
Dennis P Chapman
Liked 53 Times in 25 Posts
What brand of computer are you using.
Dennis P Chapman 1904 STK
Old 12-09-2009, 12:07 PM   #14
Marc Kinton
Stock Ford computer, MSD Ignition box.
Old 12-09-2009, 01:38 PM   #15
Dennis P Chapman
How much boost are you getting out of it.
Old 12-09-2009, 01:41 PM   #16
Dennis P Chapman
Also auto or stick.
Old 12-09-2009, 01:48 PM   #17
Marc Kinton
21 lbs. max. only 11 lbs. off the line. Automatic transmission conversion, car came stock with manual. max. rpm off the line is 2800 or it starts rolling the beams any higher. stock brakes and master cylinder.
Old 12-09-2009, 01:57 PM   #18
Dennis P Chapman
Whats your 60' and ET.
Old 12-09-2009, 02:30 PM   #19
Liked 5,139 Times in 1,962 Posts
Are you running it up against a 2 step on the line?
Old 12-09-2009, 03:22 PM   #20
Marc Kinton
two-step/ yes
i will get the log book this afternoon and give you guys the incrementals
thanks again for the help; i really want to make this work
