Old 12-08-2009, 03:40 PM   #1
Karl Owens
Default Pontiac Blocks Heads Cranks326 400 455
I have several Pontiac engine blocks and heads
1966 326 2bbl Long Block less timing cover $100
1968 400 Bare Block .030
1969 400 Bare Block STD $300
1970 400 block STD factory drilled for 4 bolt mains w NEW Pro Gram 4 bolt caps $600 (needs to have caps installed has stock caps now)
1975 455 STD bore block $350
1969 #48 heads have 3 one in very poor condition good for r&d crossover filled w AL BARE w new Ferrea stock repl valves $700
1968 #16 Complete used core heads $400
1
Karl Owens is offline   Reply With Quote
Old 12-12-2009, 01:23 AM   #2
tranzbuilder
Default Re: Pontiac Blocks Heads Cranks326 400 455
where are located ? have any of the block's or the #16 heads been magnafluxed ? also will you sell the 1970 block without the pro-gram caps ?
tranzbuilder is offline   Reply With Quote
Old 12-18-2009, 02:59 PM   #3
triathlonx13
triathlonx13's Avatar
Question Re: Pontiac Blocks Heads Cranks326 400 455
1
Where are you located?
triathlonx13 is offline   Reply With Quote
Old 12-18-2009, 03:08 PM   #4
Karl Owens
I am in New Castle Delaware between Philadelphia and Baltimore
I will sell the block with stock caps.
I will mag the heads but I removed them from a runing engine w no issues
Search this Thread:
Advanced Search
