#11 | |
Liked 8 Times in 7 Posts
that looks more like the wheel mounting surface (flange to flange) measurements try not to end up with a truck 12 bolt... ![]() Last edited by Tom keedle; 12-08-2009 at 05:35 AM. |
#12 |
I measured the housing flanges outside to outside and it measures 55 1/4 "
#13 |
Liked 335 Times in 182 Posts
My source tells me
64-67 is 56 1/2 flange to flange and 60 1/2 outside of brake drum to outside of brake drum 68-72 measurements are/is 58 1/2 and 62 1/2 68 was the transitional year so some early 68 vehicles might have leftover 67 housings anyway kdc info is still correct--Comp 387 |
#14 |
i measured the welded on flanges that the brake plate bolts too that are on the axle tubes.
i guarantee it's NOT a truck rear. Last edited by stock eliminator; 12-12-2009 at 08:34 AM. |
#15 |
Liked 309 Times in 88 Posts
55 1/4" is the flange to flange measurement for a 68-72 Chevelle or Monte Carlo housing.
#16 |
i've got a 67 chevelle sitting out back of the shop right now BUT it's covered in that white stuff right now.
got a 10 bolt in it though.. how big of a hurry are ya for measurements?or is that even what you need? i AM surpised at all the chevelle info that's out there, that there isn't any code charts... |
#17 |
Go to a website CHEVELLESTUFF.COM one of the best out there gives you almost everything you need to know about deciphering GM codes on these cars---Comp 387
