Old 12-12-2009, 10:20 AM   #1
L79racer
L79racer's Avatar
Default PG gear ratio?
Looking for some input for first gear ratio. What would you recommend for my car. 2850lbs 383 small block, 29" tire with 4.56 gears. Shifting at 7200 running through the traps at 7000. Cars been 10.20's at 130 foot braking it with 4000 stall glide and a 1.94 gear set. 4 link car. Just loosen the converter to 4800. 8" ATI converter. Smaller, bigger looking for opinions from experience. I'm new to automatics and the gear set broke so I need another one. Thanks, Vinny
L79racer is offline   Reply With Quote
Old 12-12-2009, 10:27 AM   #2
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default Re: PG gear ratio?
1.94 or 1.98 should be fine for that combo,loosening the converter will help ALOT 4000 was to tight.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 12-12-2009, 11:05 AM   #3
L79racer
L79racer's Avatar
Is there a big e.t. difference from 1.80 to 1.94 or is it minimal? At 130 mph should this go into the 9.90 range? Same combo with a stick was going 133 mph.
Old 12-12-2009, 12:38 PM   #4
283SS
with a 383 and that light of a car just put the stock 1.76 gear set in the car and race if u do try to run the stock 1.82 u will have to pull in out after about 100 runs any more runs chanse of braking it
283SS is offline   Reply With Quote
Old 12-12-2009, 01:23 PM   #5
L79racer
L79racer's Avatar
I'm going to trans brake it and I dont think the stock 1.76 gear will last plus I want to break into the 9's and I think it will need more than the 1.76 gear.
Old 12-12-2009, 01:39 PM   #6
283SS
ow yes 1.76 will last even longer sens u running a small block 383 how much motor u got? I ran 1.76 with 406 for yrs low 10s and never broke in 3300 pound car tried 1.96 gear set and car did not like it to much first gear for the power
Old 12-12-2009, 01:53 PM   #7
L79racer
L79racer's Avatar
maybe 550 to 580 hp. Its just a pump gas motor street car. When you switched to the 1.96 what did you loose in 60' and et? What rear gear and tire were you running? I really want to get this thing into the 9's
Old 12-12-2009, 02:26 PM   #8
283SS
lost on 60 and et cant remember how much been so long my car head 4.56 gears and 32-14.5w stiff side wall lunch at 5500 on brake shift at 6500 and 6800 at finsh line
Old 12-13-2009, 10:01 AM   #9
L79racer
L79racer's Avatar
Anybody else want to add what gear they run and et?
Old 12-14-2009, 09:46 AM   #10
Darrin Christen
Darrin Christen's Avatar
I ran a 355" sbc in a 2860# chevy II with a 1.76 glide 5.67 rear gear. Car went a best of 1.33 60' @ 9.86 and consistent 9.90's @132mph at 8200 rpm in cool weather. I put a 2.03 low gear and 5.43 rear gear. 60' times dropped to 1.30-1.29 and ran basically the same E.T. and mph at 7900 rpm. You will have more rpm drop at gear change with the lower gear ratio. Car has a 8" 5800 convertor and a 15" x 33" 105" roll out. I leave with the trans brake at 4200 rpm. The car was more consistent with the 2.03 low gear due to being able to transfer the weight better, and a whole lot more fun to drive! The 2.03 broke after about 350 runs. I put the good old reliable 1.76 back in for now! Hope this helps.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
