Old 12-15-2009, 07:54 PM   #1
FED 387
Liked 333 Times in 180 Posts
Question 82-92 Camaro steering box questions
Did ANY 82-92 Camaro /Firebird come from the factory with MANUAL STEERING or was Power Steering Standard equipment on ALL cars???? If they did indeed come with MANUAL steering what/which models had MANUAL steering and does anybody have either the GM part number or the Hollander interchange number???? Thanx comp 387
Old 12-15-2009, 07:58 PM   #2
Doug Blackley
Doug Blackley's Avatar
Default Re: 82-92 Camaro steering box questions
Power steering was standard equipment during those years. You can use a manual box out of a mid 80's S10 pickup.
Doug Blackley 1697 STK
Old 12-15-2009, 08:04 PM   #3
FED 387
OK what pitman arm and centerlink do you use to get the correct steering or do you use the original Camaro stuff??? Comp 387
Old 12-15-2009, 08:08 PM   #4
Doug Blackley
I just used the S10 pitman arm and used the Camaro centerlink.
Old 12-15-2009, 08:12 PM   #5
FED 387
Dave--- with these mods how is the steering???? Dragstrip car use only!!!!---Thanx for the info Comp 387
Old 12-15-2009, 08:27 PM   #6
Doug Blackley
It's not too bad. The S10 box is not as quick ratio as the Camaro one though. I wouldn't go back to p/s if I ever decide not to race anymore and reregister it for street use.
Old 12-15-2009, 08:31 PM   #7
Larry Munk
I used a chevy Monza manual box once and it woked fine too. They are sorta the same family of platforms.
Larry Munk is offline   Reply With Quote
Old 12-15-2009, 08:35 PM   #8
FED 387
Thanx guys for the answers---It seems we need to get us a S10 box tomorrow---Thanx comp387
Old 12-16-2009, 06:03 AM   #9
Dragsinger
Liked 99 Times in 60 Posts
the S - 10 box works fine. The "slow" ratio makes steering easy.
Larry Woodfin 471W
