Liked 20 Times in 15 Posts
i have a Jessel belt system on my 265. i degreed the cam in, and had to go -1 to get it 'straight up'. my desk top dyno says +2 is the best HP.
my question is: to get +2, do i move the cam to +1, [that would move the cam 2 degrees] or to +2, [which would be 2 degrees + from true 0].? seems sort of picky, however this small baby mouse needs everything it can get. the chart also showed +4 to be very close, loose a little at 5k and gain a little at 7k. thanks rod |
Liked 1,928 Times in 434 Posts
No, to get 2 degrees advanced, you need to move the cam 2 degrees advanced from straight up. What matters is where the cam is, not what the marks on the timing components say.
Alan Roehrich 212A G/S |
Liked 319 Times in 108 Posts
If your on -1 move to +1 will be 2degrees adv. What I always do is mark cam spider w/ sharpie as example say 106 is straight up for your cam I would mark it -1=106 so you always have your baseline to go back to.
Mike Taylor 3601 say intake CL calls for 106 and to degree to 106 spider shows -1 then you move to +1 you'll be @104 Last edited by Mike Taylor 3601; 12-16-2009 at 08:15 PM. |
Liked 18 Times in 4 Posts
I have found that the marks don't always tell the truth. The only way to know for sure is to change it when you assemble and measure it at several different spots. Although I have moved mine around quite a bit it doesn't seem to make too much difference on the time ticket. But this was all done on a Super Stock 454 that makes quite a bit of torque so it may change your combo more.
I have found that only one place make the best power when we dyno and it seems to run the best there on the track too. Only talking .03 or so difference either way. On your earlier post the merge collector does change the jetting some. A lot of it has to do with how small the neck down is and how long overall collector is. We have seen the smaller the neck down size the narrower and higher the power band. Hope this will help!
Bryan Broaddus 7568 STK ,SS |
