Old 12-16-2009, 09:49 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default trans low gear, stall speed input.need help
motor is 400 sm block running compression 12/5/1,trans haves a 211 low gear,8inch converter with a 5,000 stall,rear gear is 488 on a 29/9/15,weight of car is 3150,and shifting at 6500 and going thought the traps at 6800,cam is Q.50 int/236 and exh/242 best et is 10.51 at 125.12 off trans brake. need help or input on stall speed was told that I need a 4,000 stall would really not like to waste money on wrong stall speed. we are changing cams over the winter and going with a Q.50 int/249 and exh/262. thanks for help!!!
TinSoldier 3215 is offline   Reply With Quote
Old 12-16-2009, 09:59 PM   #2
Dennis Paz
Liked 5 Times in 3 Posts
Default Re: trans low gear, stall speed input.need help
Converter stall is fine but 211 low is a bit steep. put a taller low gear in it and let it run on the torque further down the track. Also way less volatile on starting line.
Dennis Paz is offline   Reply With Quote
Old 12-16-2009, 10:02 PM   #3
Dennis Paz
I have an ati straight cut 1.90 that has like 5 passes I might trade for a 2.11.
Old 12-16-2009, 10:14 PM   #4
TinSoldier 3215
Hey Dennis, what do you mean go to a taller low gear? we have a 176 low gear.and less volatile on starting line what do you mean?
Old 12-16-2009, 10:27 PM   #5
Dennis Paz
Your post says
TRANS HAVES A 211
Old 12-16-2009, 10:31 PM   #6
TinSoldier 3215
yes we have a 211 low gear in the car now. and a 176 spare.
Old 12-16-2009, 10:37 PM   #7
Dennis Paz
Bracket car?
I have a 68 nova that had a mild 400 that ran 11.50 with a 1.76 and tried a 1.96 and all that did was made the car spin on marginal conditons. Car was maybe a tenth faster on a killer track but would not repeat when track whent away(9x30 tire).
Old 12-16-2009, 10:41 PM   #8
TinSoldier 3215
yes bracket car.
Old 12-17-2009, 02:41 AM   #9
283SS
tell us more about the motor please and with a 400 ci smaill block u dont need that much first gear I could say u my need to go 5500 on your convertor but need more into on what in the motor before i say that
283SS is offline   Reply With Quote
Old 12-17-2009, 10:46 PM   #10
TinSoldier 3215
Hey 283, what do you need to know about the motor?
