Old 12-18-2009, 02:33 PM   #1
PJ305
Liked 5 Times in 4 Posts
Default Index Change
Now posted on Lucas site
PJ305 is offline   Reply With Quote
Old 12-18-2009, 02:49 PM   #2
Chad Rhodes
Default Re: Index Change
Oh well (note sig change from AA/SA to A/SA), it effects everyone the same. Unless you can't run .3 under
Chad Rhodes 2113 I/SA
Old 12-18-2009, 02:56 PM   #3
Sean Ward
Sean Ward's Avatar
Send a message via AIM to Sean Ward
can you post the link someone thanks
Sean Ward NHRA s/ss/comp#2882
SW4 MOTORSPORTS
Sean Ward is offline   Reply With Quote
Old 12-18-2009, 03:09 PM   #4
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
Here is the link:
http://www.nhra.net/content/sportsma...9436&zoneid=85
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 12-18-2009, 03:10 PM   #5
fredjohnston
Liked 55 Times in 14 Posts
The AHFS will impact very few combinations with the new indexs. The HP committees job just got alot easier.
The new Mustangs and Mopars will most likely never see an adjustment.
The proper way to adjust horsepower ratings is to take the average under the index runs of each car/engine combination and average them against each other.
Example: car/engine average for combination X = .95 under index
car/engine average for combination Y = .75 under index
The HP needs to be adjusted for up (raised) for combination X or lowered (decreased) for combination Y.
They aren't reinventing the wheel or performing brain surgery here.
fredjohnston is offline   Reply With Quote
Old 12-18-2009, 03:33 PM   #6
Casey Miles
Liked 508 Times in 92 Posts
Talking Re: Index Change
WOW!! Now I can run all out and not worry about getting too far up the qualifing sheet. LOL!!!
Old 12-18-2009, 03:40 PM   #7
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Or they could've just moved the trigger up .15, which is primarily what they've done. It just won't LOOK like a -1.55 under run on paper next time. Now guys can race to 1,150'. Maybe they can put a cone out there for that. Congratulations, NHRA, you've accomplished.... um.... something, I guess.
Old 12-18-2009, 03:42 PM   #8
Charley Downing
Liked 653 Times in 89 Posts
What about class winners do they still need to run -.50 under to win class?
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 12-18-2009, 03:50 PM   #9
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
I'm just curious, what happens to all the records now ? Do they change, or do they just start from scratch, or will there be all new records ?
I guess this was to even things out , but it seems to me like the sand baggers will be even farther ahead now.
like if you run all out and your a sec. under , you'll be .7 under now , but if you were holding some at a sec. under , now you can run it hard and still be ahead of the game.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-18-2009, 03:51 PM   #10
Casey Miles
NHRA could have approached the indexes a different way. They could've just made a valve spring pressure rule that would slow everyone up. Make it so that the pressure can't exceed 150 lbs on the seat. But NHRA doesn't want to work for their membership money which means testing pressures of the valve springs.
Casey Miles
248H (Exceptionally/Slow)
