Old 12-20-2009, 01:32 PM   #11
7820
7820's Avatar
Default Re: Readjustment letter to NHRA
No offense taken....but you took the letter from a business letter and made it a personal attack. Porbably will not be received and reviewed with much enthusiasm.
7820 is offline   Reply With Quote
Old 12-20-2009, 01:58 PM   #12
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
Not a personal attack, just an observation and suggestion. The results will probably be the same as before.
Ron Ortiz
U/SA waitig
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 12-20-2009, 02:15 PM   #13
Jack McCarthy
Liked 476 Times in 117 Posts
RON... you need to send a HP reduction request since you got screwed when the early cars with the better carb got YOU hit with HP... send it today - contact Roy Dean for more info and another letter sent same time
you are right, but they can stuff all the AHFS up thier ***** couse it will never work... just give us a HP committee with woodro, provoast, travis, wesley...you get the idea engine guys with sense tech guys with balls... and let the chips fall where they may...if fords end up in SS so be it... travis tossed em at indy !
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 12-20-2009, 02:41 PM   #14
Bill Koski
Bill Koski's Avatar
Default Readjustment letter to NHRA
Since two speed automatics can be replaced with three speeds in certain cars it doesn't seem to me allowing a '66 or '67 car to use the larger carbeurator a '65 that is rated at the same horsepower can run would be nearly as big a variation!
Bill Koski is offline   Reply With Quote
Old 12-21-2009, 11:28 AM   #15
Ron Ortiz
Ron Ortiz's Avatar
Jack, appreciate the info, but I wasn't looking for a HP reduction. I was makeing an observation of how Stock Eliminator seems to be somewhat influenced.
Bill, yeah, whats the difference with a little CFM.
Ron Ortiz
U/SA lower hp ha ha
Ron Ortiz 2102 STK
Old 12-21-2009, 02:28 PM   #16
Clayton Wright
Liked 13 Times in 4 Posts
Sounds like a good idea to me Bill. Then we can all go back to 165Hp and race on an even playing field. I'm all for it. Thanks for the great idea.
Clayton
Clayton Wright 1980 STK
Clayton Wright is offline   Reply With Quote
Old 12-22-2009, 02:06 PM   #17
Jack McCarthy
what two speed cars can replace with a 3 speed in stock (unless it is in the 2010 rules ?)
if you are discussing the 1957 - 1961 issue i had approved it is a fact these cars were equipped with a 3 speed transmission called a "turboglide" from the factory... since you guys are my U/SA buddies i will be happy to supply you with the data i supplied NHRA with which resulted in thier identifying this as fact and approving ONLY 1957 -1961 full size chevrolets as so equipped ... just ask !
jack
and by the way so far i have found VERY little performance advantage
"the Captain"
Old 12-22-2009, 02:22 PM   #18
Jeff Teuton
Liked 325 Times in 50 Posts
Capt, was that the thing with the "GR" next to "D" on my mama's 57 Chev? I thought it was a turbine. It ran like a Buick Dynaflow. But then again.....
Jeff Teuton 4022 STK
Old 12-22-2009, 03:05 PM   #19
Jack McCarthy
Smile Re: Readjustment letter to NHRA
that was it jeff... BIGGG said GR was for "get ready"
anyway 2 planetarys + direct drive = 3 speed ... also had a 3 turbine convertor was a pile of ***** that is why i dissapeared out of NHRA books when you had to run the factory transmission it sucked... but when enhanced by the "any corporate trans with same number of gears" rules... shazam its a turbo !
anyway jeff merry christmas to all my mopar friends down south and see you all at pats place in march !!
jack
"the Captain"
Old 12-22-2009, 05:17 PM   #20
Liked 5,121 Times in 1,952 Posts
[QUOTE=Jeff Lee;
Your first sentence has the reader of your letter saying "F-You" and then it hits the trash can![/QUOTE]
It's already there. They had someone come in from vacation, just to toss it .
They wouldn't want you to expect them to work for their salaries next year.
