Old 12-27-2009, 11:31 AM   #1
randy wilson
Liked 22 Times in 22 Posts
Default oil pumps
is there any horse power difference between a stock type pump, a external pump, or in pan billet pump, as far as turning it goes?
don,t have one
Old 12-27-2009, 12:08 PM   #2
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: oil pumps
yes--Comp 387
Old 12-27-2009, 03:35 PM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: oil pumps
i can't give you any exact numbers but on an external belt driven , just lowering the oil pressure makes a noticable difference when priming it with a drill.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-27-2009, 06:58 PM   #4
randy wilson
thanks guys, but which one is better? in comps opinion, i have all 3, which one would you run?
don,t have one
Old 12-27-2009, 07:35 PM   #5
FED 387
what engine- what rpm -what type/class of racing?? comp 387
Old 12-27-2009, 08:33 PM   #6
randy wilson
ss/cs g/sm 10400 rpm thanks comp, no. we will not be a threat, just want to get in.
don,t have one
Old 12-27-2009, 09:16 PM   #7
FED 387
Randy-- sent u a PM--- Comp 387
Old 12-28-2009, 09:08 AM   #8
randy wilson
thanks guy, you have been a big help. sent you a pm hope it went through.
don,t have one
Old 12-29-2009, 12:13 AM   #9
FED 387
got it sent u another PM--comp 387
Old 12-31-2009, 02:15 PM   #10
Ray Menard
Ray Menard's Avatar
Hi Randy,
I also run a SS/CS Small Block Chevy and I use a external belt driven Razor Combination oil pump/vacuum pump unit. It has adjustable oil pressure springs, is compact and trouble free over the past 3 years.
Contact: Terry Palmer (480) 615-7700
Ray Menard
SS/CS (SS/DM & SS/EM)
#7386
Ray Menard is offline   Reply With Quote
