Old 01-04-2010, 11:59 AM   #11
Bob Don
Bob Don's Avatar
Liked 903 Times in 192 Posts
Default Re: Just an idea to combine classes.
I've been reading some recent post about Top Stock and got started thinking (usually bad thing). Maybe it's time to "shake the cage" a bit and think about going to 2 pound class breaks. Leave AA alone at the top and go to 8.00 to 9.99, 10.00 to 11.99 etc. Keep sticks and autos seperate. Also, no class adjustments up or down just top of natural class.
That should make things interesting! I know it would hurt everything I own but WTF.
Billy - If you're gong to do that, then class should be contested at every event (even divisionals and opens) and ONLY class winners can run the eliminator!
Old 01-04-2010, 12:25 PM   #12
Billy Nees
Liked 7,789 Times in 1,744 Posts
I don't ever see that happening.
Billy Nees 1188 STK, SS
Old 01-04-2010, 12:32 PM   #13
Chris1529
Liked 70 Times in 29 Posts
sounds like a good idea. I'll put one of the new 428" small block crate motors in my car.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 01-04-2010, 01:52 PM   #14
Dick Butler
Liked 32 Times in 19 Posts
Billy, Good Thoughts. I agree with X-Tech When I discussed this type of thing it was threatening. But it could be best for all parties in the long run. NHRA needs to make it worth while to run fast. Points for class wins, Points for Records, that affect a HP of a combination then pushing it to Win class would be some gain.
Sticks + Auto , GT and SS together with wt break for SS car against GT chassis 50 lb light?
With having more class racing more often possible by having more of a certain class at events NHRA could have class which would be meaningful not Bye Runs for trophy taking a 1/2 day of event time.
I honestly think some Manufacturers could be coaxed to pay class more often if there were only 1/2 the classes to pay or fewer..
For those slower in a class there is still eliminator if you run Quick enough to Qualify so you only have More runs at the meet with class to run too.
Old 01-04-2010, 05:44 PM   #15
art leong
I absolutely DISagree with that! Keep things as diverse as possible.
Billy As you can plainly see there is no way of changing this without severly hurting someone.
Why do some people think if the number of classes are cut that payout will go up?
PS I have a bridge for sale. Only Slightly Used.
Art Leong 2095 SS
Old 01-04-2010, 07:51 PM   #16
JRyan
Liked 112 Times in 31 Posts
Dick,
MOST racers could give less than a S**T if they get points for anything. In case you hadn't noticed, there aren't a whole lot of people contending for points Nationally or at the Division level. Billy posted a reasonable thought that may be a little off to some, but then you went ahead in your usual way and made a complete cluster out of it.
Let's not combine Sticks & Autos. There are lots of classes where because of low counts in the class, the STICK guys have never found it necessary to buy THE GOOD STUFF to go fast. If they do, you'll see the STICK advantage show up in many more classes. Remember, there are some high HP Stick cars now running radials, so there goes that perceived advantage for the autos.
It ain't broke folks. If you want to hurry the demise of Stock/SS to the point that only the elite can play, go ahead and combine a bunch of classes. When you reach the point where only a few feel it is worth it to play, you'll have completed the demise of the whole class system. NHRA will just say GOODBYE!
Old 01-04-2010, 08:47 PM   #17
Dick Butler
JRyan,
It is interesting someone always comes up with a point of fear that no one will be able to play if the classes were combined, no one would come to race, No new racers would build cars.
You and others act as if Combining classes is an Alternative to Eliminations. If you fall in a class with 10 cars tomorrow intead of 2 cars today , no one says you are not elgible for eliminations if you qualify JUST LIKE TODAY. But NHRA has a car count showing up at meets with greater numbers of same class to make the "show".(Fewer BYE run classes)
Making Class racing a bigger part of the racing can just give more fun as TOP/STK, TOP/SS do. Most who ran this declare it to be " the most fun I have had in years"
It is Just combined classes and stick and Auto HEADS up. An example of Combined classes for more "racing"
My opinion from Being in Bigger classes all my life and organizing TOP/STK and TOP/SS in Div 3 . It may return when larger numbers of cars to fit are available.
Old 01-04-2010, 09:15 PM   #18
art leong
Originally Posted by Dick Butler View Post
JRyan,
Dick how are your car counts lately?
How do you think they will be when the Cobra Jets and the Challengers take over?
Art Leong 2095 SS
Old 01-04-2010, 11:22 PM   #19
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Thumbs down Re: Just an idea to combine classes.
That should make for some exciting and close Heads Up races that the fans would go wild over!
Old 01-04-2010, 11:35 PM   #20
Bobby Fazio
Bobby Fazio's Avatar
Originally Posted by GUMP View Post
I think that the first step should be to combine sticks and autos.
If this happened their wouldn't be one stick car at the racetrack.
'65 Mustang SS/L & L/SA
