Old 01-05-2010, 02:11 PM   #91
tj310
Default Re: Lencos in SS
Question for Sean How do you know if drivers in videos are clutching?
Thanx Trevor
Old 01-05-2010, 05:46 PM   #92
Rory McNeil
Originally Posted by randy wilson View Post
let me restate my question, if a motor pulls good from 8200 to 9900, and you lock it down hard in all 5 gears, and you see it never dropped below 8400, and did not blow the tires off, what benefit is slipping the clutch?
Lot of "IF`S" there! but Assuming it was "locked down hard" didn`t blow the tires off", I`d be betting the car owner would likely have a nice collection of broken clutch hubs,main shafts, trans gears, U joints, driveshaft yokes, ring & pinions, etc etc......
NHRA 6390 STK
M/S 85 Mustang
Old 01-05-2010, 06:10 PM   #93
randy wilson
Liked 22 Times in 22 Posts
rory, i understand what you are saying, when i say locked down, i mean a normal lock up of the clutch. everything in the drive line absorbs some of the shock. my theory is if the motor stays in its power range, would it be safe to say that the more clutch the faster you will go or am i missing something. i am not being sarcastic, i am trying to learn. i know people are slipping the clutch and running faster. i just dont know why in some instances. we have a computer and are just learning with it. we do not know exactly what to look for. it is possible our motor is not building enough hp that this will come into play.
don,t have one
Old 01-05-2010, 07:34 PM   #94
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Pvt Parts,
75 nova K/S 3720Lbs. You have to pull hard, first pass or two I missed shift points cause
I didn't pull hard enough.
Randy,
Is your car the Cobalt on you tube 11,000 rpm cobalt?
Mike Taylor3601
Old 01-05-2010, 08:49 PM   #95
randy wilson
yes mike, it is. if you click on camaromitch it will take you to the runs at osceola, the 11000 rpm takes you to our local track which was spec and all heads-up. all driven and owned by steve thompson now. we our partners. best partner and driver i have been with. he never gives up. thanks for asking.
don,t have one
Old 01-05-2010, 10:20 PM   #96
SuperStockDodge
SuperStockDodge's Avatar
Thanx Trevor
I know the difference-trust me.
Sean Fischer 5864 SS/E
SuperStockDodge is offline   Reply With Quote
Old 01-05-2010, 10:27 PM   #97
Scotty D
if you have a trained ear you can hear the differance in a shift with the clutch versus without.
Scotty D is offline   Reply With Quote
Old 01-05-2010, 11:22 PM   #98
Pvt Parts
Pvt Parts's Avatar
Go listen to a round of Comp Eliminator and you'll hear the difference.
Old 01-06-2010, 08:42 AM   #99
SuperStockDodge
Absolutely, you can also SEE it in the gear changes as well... You would really be able to know if the clutch was being used if you were able to ride along. LOL
Old 01-06-2010, 08:44 AM   #100
Mike Taylor 3601
I love to listen to cars on Houston 1 &Houston 2 videos. I think a car clutch shifted still sounds better,I still love the sound of a heavy flywheel car also.
Mike Taylor 3601
