#91 |
Question for Sean How do you know if drivers in videos are clutching?
Thanx Trevor |
#92 |
Liked 1,112 Times in 304 Posts
Lot of "IF`S" there! but Assuming it was "locked down hard" didn`t blow the tires off", I`d be betting the car owner would likely have a nice collection of broken clutch hubs,main shafts, trans gears, U joints, driveshaft yokes, ring & pinions, etc etc......
#93 |
Liked 22 Times in 22 Posts
rory, i understand what you are saying, when i say locked down, i mean a normal lock up of the clutch. everything in the drive line absorbs some of the shock. my theory is if the motor stays in its power range, would it be safe to say that the more clutch the faster you will go or am i missing something. i am not being sarcastic, i am trying to learn. i know people are slipping the clutch and running faster. i just dont know why in some instances. we have a computer and are just learning with it. we do not know exactly what to look for. it is possible our motor is not building enough hp that this will come into play.
don,t have one |
#94 |
Liked 316 Times in 107 Posts
Pvt Parts,
75 nova K/S 3720Lbs. You have to pull hard, first pass or two I missed shift points cause I didn't pull hard enough. Randy, Is your car the Cobalt on you tube 11,000 rpm cobalt? Mike Taylor3601 |
#95 |
yes mike, it is. if you click on camaromitch it will take you to the runs at osceola, the 11000 rpm takes you to our local track which was spec and all heads-up. all driven and owned by steve thompson now. we our partners. best partner and driver i have been with. he never gives up. thanks for asking.
don,t have one |
#96 | |
Sean Fischer ![]() |
#97 |
if you have a trained ear you can hear the differance in a shift with the clutch versus without.
#98 |
Go listen to a round of Comp Eliminator and you'll hear the difference.
#99 | |
#100 |
I love to listen to cars on Houston 1 &Houston 2 videos. I think a car clutch shifted still sounds better,I still love the sound of a heavy flywheel car also.
Mike Taylor 3601 |
