Old 01-06-2010, 12:37 AM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Question Thick Valve Spring Shims?
Does anyone make a valve spring shim thicker than 0.060"?
I am looking for something in the 0.100" range so i do not have to stack up 2 of the 0.060 thick shims. My thought is that the fewer amount of shims I use the better I can keep things running straight and true to the valve rather than stacking up a bunch of shims that could make the spring sit out of square.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 01-06-2010, 01:07 AM   #2
STK4340
Default Re: Thick Valve Spring Shims?
Have you thought about using -0.050" locks and only one 0.060" shim? Just a thought...
STK4340 is offline   Reply With Quote
Old 01-06-2010, 09:28 AM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Use a spring cup or id type spring seat plus the shim.....
Rich Biebel
S/C 1479
Stock 147R
Old 01-06-2010, 09:42 AM   #4
ron mattson
Liked 66 Times in 29 Posts
call matt steen at victory engines 507-532-2436 he can custom make anything you need
i have had them made up to .250 thick with a center locating ring works great,
ron mattson is offline   Reply With Quote
Old 01-06-2010, 10:00 AM   #5
Ed Wright
Ed Wright's Avatar
That is what I use. If that and a locating spring seat still won't get it I add shims. The -.050" locks get you more clearance from the rockers too.
Ed Wright 4156 SS/JA
Old 01-06-2010, 11:38 AM   #6
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
What dia. springs are you using.
STK1217 is offline   Reply With Quote
Old 01-06-2010, 02:42 PM   #7
Chad E532
Chad E532's Avatar
I am running 1.500" OD dual springs. The heads were setup for 1.950 installed height with the hardened locators and 0.030" of shim already under the locators. They are AFR 195 Eliminator heads that run 8mm 10 deg retainers and keepers so I am not sure if anyone makes the -0.050" drop retainers. I looked at AFR and they only list the "standard" height versions. I originally bought the heads assembled with their springs, but on this winters refurb I was planning on installing the correct springs from the cam card which run the different height.
Thanks
Chad
Old 01-06-2010, 02:54 PM   #8
Ed Wright
Ed Wright's Avatar
Thanks
Chad
Comp does. I use 1.5" PAC springs, and Comp has both the retainers and both -.050" and +.050" locks
Old 01-07-2010, 01:19 PM   #9
Jeff Lee
Jeff Lee's Avatar
Use a spring cup. Buy or have one made if necessary. It will help control the spring, especially if you have multiple shims under the spring right now. I picked up some good RPM when I made the change on my stocker.
Jeff Lee 7494 D/S '70 AMX
