Old 01-10-2010, 10:36 PM   #1
rod
Liked 20 Times in 15 Posts
Default coil wire through firewall ?'s
my MSD and coil are inside under the dash. the coil wire goes through a 1" rubber grommet. i have one of the MSD coil wire connectors, but never have used it.
so the questions are:
1 does it really make any difference?
2 should i use the two ended connector?
thanks rod
rod is offline   Reply With Quote
Old 01-10-2010, 11:33 PM   #2
Jim Bailey
Liked 584 Times in 94 Posts
Default Re: coil wire through firewall ?'s
Rod, don't use the connector. One coil wire only , as short as possible. Grommet through the firewall. And change the wire often. JB
Jim Bailey is offline   Reply With Quote
Old 01-11-2010, 01:47 AM   #3
Philip Saran
Liked 14 Times in 11 Posts
Jim, so are you saying on my BB Duster I would be better off keeping the MSD
coil where it is on the right inner fender with a short coil wire.
Instead of inside under the dash with the MDS box?
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 01-11-2010, 09:33 PM   #4
njk53
Place the coil under the dash as close to the distributor as possible to keep the length of the coil wire as short as possible. I use the MSD bulk head connector that utilizes 2 short wires. Not sure if there is an advantage to having 1 wire versus 2. That would be a good question for the MSD Tech Dept. There are at least two advantages to having the coil out of the engine compartment. 1) The decrease in heat will make the coil last longer and 2) Coil will perform better over time due to less internal degredation caused by heat.
Nelson Kowal
Stock 345
Old 01-12-2010, 10:33 AM   #5
Ed Wright
Ed Wright's Avatar
There ya go.
Ed Wright 4156 SS/JA
Old 01-12-2010, 12:25 PM   #6
SCOTT SST2871
I have the firewall connector on my car with 2 short wires(total length about 10 inches)been that way for 15 years,never had a problem.coil and msd are 21 years old......and yes keep the wires fresh,just my take
scott fifield
SCOTT SST2871 is offline   Reply With Quote
