Old 01-15-2010, 10:36 PM   #11
wagonboy
Liked 26 Times in 5 Posts
Thumbs up Re: weight.....help
Pat,
Trying to. I figured I was not loosing money fast enough with a bracket car. I want more abuse- and a higher price tag for the abuse. My wife really talked me into it......... she thought there might be a more effective way to burn money! So I gave in and got a stocker. I am still racing the Falcon and will be till the dinosaurs come back.
Good to hear from you. I will chime in once I take it back out in a month or so.
Ryan
wagonboy is offline   Reply With Quote
Old 01-19-2010, 09:51 AM   #12
wagonboy
Smile Re: weight.....help
ok, bear with me here. If my car fell into N naturally - would the recipe for weight be 14.50 x (hp) 230 = # plus driver weight OR would it be where the car falls 14.66 x (hp) 230 + # plus driver weight. I understand if I move to O- I would multiply by 15.00- the lowest number. Question is for my natural class would I use the 14.66 or 14.50 (min) ?
Thanks
Ryan
Old 01-19-2010, 10:01 AM   #13
Tom Moock
Liked 10 Times in 6 Posts
Default Re: weight.....help
Wagonboy, 1983 Malibu wagon - 230 hp. m=3390, n=3505, o=3620 min. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 01-19-2010, 11:27 AM   #14
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Thanks
Ryan
You can use the top of each class' weight break to figure class minimum weight. 14.00 (M/SA), 14.50 (N) and 15.00 (O) x NHRA rated HP + 170 = minimum weight for each class.
Old 01-19-2010, 12:49 PM   #15
Duster 7695
Liked 8 Times in 6 Posts
Ryan - Are you going to run stock this year?
Raul
Duster 7695 is offline   Reply With Quote
Old 01-19-2010, 04:55 PM   #16
wagonboy
Thanks Mike, and Tom.
Tom, looks like the cam is a little bigger for the 83 too! That may help a little.
Raul- I am trying to. I am on the cusp of getting her under, so we will see. I will run mostly div if I can get .2 under or so.
Thanks
Ryan
Old 01-19-2010, 07:10 PM   #17
Tom Moock
Wagonboy, the cam is the same 1980 to 1983, The bigger cam motor has flat top piston`s and small cam motor has dish piston`s, the large cam motor runs in j,k,l -253 hp. Tom
Tom Moock 5704 STK
Old 01-19-2010, 07:20 PM   #18
wagonboy
Tom,
Thanks for the tip. I over looked that .
Ryan
