Old 02-01-2010, 08:58 PM   #1
283nova
283nova's Avatar
Default clutch? which one!?
ive converted my 64 nova over to a 4 speed and was wondering what clutch is going to be the best option ive eyeballed some sintered iron units from ram, and a twin disc unit from mcleod, which one is the most commonly excepted "good one" to use? its a high winding 302 chevy launches will most likely be 5500-6500.
283nova is offline   Reply With Quote
Old 02-01-2010, 10:02 PM   #2
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Default Re: clutch? which one!?
When i had a modified 302 motor i used a MCCLOUD sintered iron clutch. iI had very good luck before switching to auto trans.
Bob Lasko
Old 02-01-2010, 11:04 PM   #3
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Call Tim Hyatt he built my McLeod. He is very racer friendly. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-02-2010, 12:05 AM   #4
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: clutch? which one!?
5500-6500 seems a little low for launching a "high winding 302". I know I'm old school, but back in the 70s I had a 331 that I left at 7600 rpm with and that was conservative to what other guys were doing at the time. Listening the revs from stick cars nowadays, I'm thinking they're still way upstairs when the hammer is dropped. My 2 cents.
I did use a McLeod unit back then and had very little problems with it. This was in a 66 Nova, around 2800lbs with 5:57 gears and a Super T-10. I miss those days. It sounds like you have a fun car there,,,,,take care.
Danny Durham
Old 02-02-2010, 09:26 AM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Use sintered iron w/adjustable pressure, pressure plate.5500-6500 why thats half RPM
for a high winding 302.I think you'll find that is way too low on launch if chassis&clutch are
right you'll probaly find leaving your high side chip will be fastest.
We launched my Dads 302 @ 10,000
Mike Taylor 3601
Old 02-02-2010, 10:08 AM   #6
Matt Welker
Liked 77 Times in 15 Posts
vote #2 for "Call Tim Hyatt"
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
Old 02-02-2010, 10:41 AM   #7
Jeff Lee
Jeff Lee's Avatar
You'll be leaving at least 7500 RPM, probably 8000 if you have a clutch that is built and managed well. A clutch not built correctly will require a low RPM launch like 5500-6000 and will bog the engine big time on launch and gear changes. The proof will be in the ET. 1320/MPH = optimum ET, no if's, ands or buts.
If you want info on "the best" as you inquired, PM me for info on the clutch manufacturer (manufacturer, not rebuilder) that has the record book covered for stick cars in Stock & Super Stock (Comp also). For a 302 I would recommend a Sportsman dual 7" on a 142t flywheel. It is a sintered iron assembly. This unit will weigh (complete, clutch, pressure plate and flywheel) in at 18 pounds.
The McLeod twin disk you mentioned is not only way to much clutch for your application, it is a diaghram pressure plate. In essence, a diaghram is more like an on/off switch and not what a serious drag car needs.
Jeff Lee 7494 D/S '70 AMX
Old 02-02-2010, 10:57 AM   #8
Rod Greene
Liked 242 Times in 81 Posts
Only one person to call for a clutch. He manufactures them gives great personal service. Like Jeff said he has the records covered even if some of the racers won't acknowledge they have his clutch. Advanced Clutches Rob YoungBlood 208-880-6214. And 6500 is way low to leave.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 02-02-2010, 07:14 PM   #9
283nova
283nova's Avatar
the car was a footbrake auto car for the last 5 years so 6500 was just a guesstimate car has never had a "brake" and this will be 1st year with a clutch. also have switched form a solid to a solid roller.
Old 02-02-2010, 10:24 PM   #10
Ed Carpenter
I have a 327 and I leave between 7600 and 8400 depending on track conditions.
Ed Carpenter
