Old 02-02-2010, 11:11 AM   #21
Jeff Lee
Jeff Lee's Avatar
Default Re: Camshaft
The cost issue of going larger (50-55mm) is somewhat secondary to what the racer may be really after, and that is having a billet cam core. The reason racers go for a billet cam core is it is may be more compatible with the lifters he is running (Schubeck, tool steel or other non-OEM but allowable materials), and is less prone to flex or twist. This transition of course is a result of the extended RPM ranges you see in Stock.
So the thought is, if your going to run exotic lifters, might as well have a cam core that is more appropriate to the lifters. And if you run a larger core as Dwight Southerland stated, you receive the benefit of a better ramp. And if your going to do all of this, might as well straighten out the cam tunnel (which often frees up HP anyways), and then roller bearings as then you have less concern about wiping out babbitt bearings because you have a ton of spring pressure.
Is this for your average racer? No. But no doubt it's more common than you may think, especially in some of the faster and highly competitive ranks. Nobody said Stock was supposed to be a budget class. And if you are on a tight budget, there are still ways to be competitive and still enjoy racing.
Jeff Lee 7494 D/S '70 AMX
Old 02-02-2010, 01:46 PM   #22
Ed Wright
Ed Wright's Avatar
Originally Posted by Alan Roehrich View Post
I do, you just won't tell me enough.
Ditto!
Ed Wright 4156 SS/JA
Old 02-02-2010, 09:29 PM   #23
Jim Hanig
Liked 99 Times in 49 Posts
Originally Posted by james schaechter View Post
Jim, I think you want a poll, not an answer. If you want a poll, I think you can set one up on this forum to gather opinions.
If you want an answer, contact NHRA. I would suggest proper channels like your Div Tech person.
If Travis even started answering all of the questions in this snake pit NHRA would have a cow and Travis wouldn't get any sleep either.
It might take a considerable amount of time to get an answer from NHRA, but they are the ones that will give you one.
If you still have your superstocker, I think you can bore that out with no worries with rules.
P.S. I almost hate to say it, but as far as opinions go, I think Ed had the best one on this thread.
What I was intrested in was the stock racer on the forms opinion. thats all. I aint worried if i can have one in my ss/stocker.
Jim Hanig
Old 02-03-2010, 10:54 AM   #24
Greg Turk
Greg Turk's Avatar
Liked 19 Times in 4 Posts
Jim
I'm not shy, here's my opinion for what its worth.....
No the 50mm, 55, 65...what ever should NOT be legal in stock!!!
It would be nice to add competitors to our class, not drive them away, the added cost to me would far outway the performance gains....
Turkman
TURKMAN
4002 Stock, 4002 Super Stock
Greg Turk is offline   Reply With Quote
