Old 02-23-2010, 10:42 PM   #1
rod
Liked 20 Times in 15 Posts
Default cal-tracks do's and don'ts
i just put a set on my '56 chevy. i would appreciate any help with these. mostly i am looking for: if you do this to the bars, this will be the result.
thanks rod
rod is offline   Reply With Quote
Old 02-24-2010, 01:22 AM   #2
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: cal-tracks do's and don'ts
thanks rod
Read the instructions and set the preload just like they tell you to (i think its a 1/4 turn)...not sure because I have never adjusted them since I installed them 2 years ago. The only thing I did do was move the bars to the bottom hole because if you look at the pictures on the web site all the cars dragging the bumper have them on the bottom. When I moved mine I noticed a big difference in the height of the front end when it leaves. Hope this helps.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 02-24-2010, 01:23 PM   #3
Ven302
Ven302's Avatar
Liked 34 Times in 7 Posts
Cool Re: cal-tracks do's and don'ts
Isnt that bluebottleunder the bumper why it leaves so hard?
Ven302 is offline   Reply With Quote
Old 02-24-2010, 05:29 PM   #4
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
The only "do," would be to use them in conjunction with Calverts mono springs and Rancho shocks. All cars are different. "Trial and error". Make sure you are in the car while someone adjusts them!! However, Top hole will make the car hit harder. Which is why "All cars are diff". Hope this helps, if not call Calvert and ask the tech support(s) Been there.... .
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 02-24-2010, 07:00 PM   #5
cad
cad's Avatar
Liked 93 Times in 52 Posts
I have the Cal-Tracs in the upper hole. As mentioned, the lower hole does not hit as hard which allows mine to spin badly on my local track, which is generally marginal.
I also have the Rancho Shocks from Calvert. They control body separation. Most people recommend that you have at least 4"-5" of front end travel.
I think you will want the shocks eventually.
Anyway....Install as recommended with you in the driver seat.
For adjustments, we made a wrench for the jam nuts by taking an old wrench, cutting it down to about 6" long and grinding off the sides of the head to fit into the front.
I haven't found another person that has the same adjustment as we do. Mine works best with a full turn on the bar after it makes contact with the spring. Once you find the best setup for your car, you can use adjustable shocks to hit harder or softer.
Old 02-24-2010, 08:51 PM   #6
340Cuda
Liked 805 Times in 341 Posts
This has been posted here before, by myself and others. These are the tips that John Calvert gave me over the phone when we first installed CalTracs on our car:
Top Hole – Hardest Hit (start here)
Bottom Hole – Softer Hit, moves IC forward
More Pre-load, Softer Hit
Less Pre-load, air gap, harder hit
If car pulls to the right add a quarter turn of pre-load to the right bar and visa versa.
Set front shocks soft
Set rear shocks on #5, if car wants to porpoise go to 6 or 7 (harder).
If car spins, needs harder hit, go softer
Too much wheelstand…. Softer hit, restrict front travel
We have the whole package, split monoleaf springs and Rancho shocks.
Good Luck!
Bill Lamb
Old 02-26-2010, 01:19 AM   #7
CrateCamaro
Actually my car leaves hard because I have a rubber driveshaft. When I put it up on the 2 step its actually loading the driveshaft up and when I let go of the brake its up on the bar right away.
1700 IHRA H/CM
1701 NHRA SS/?A
Old 02-27-2010, 08:18 PM   #8
rod
did you get your driveshaft where i got my hard rubber camshaft? the higher i wind it, the more lift i get!!!
rod
Old 02-27-2010, 11:24 PM   #9
Jeff Lee
Jeff Lee's Avatar
I have the rubber connecting rod option in my engine. The higher I rev it, the more compression I have!
Jeff Lee 7494 D/S '70 AMX
Old 02-28-2010, 02:21 PM   #10
Johnny U
Talking Re: cal-tracks do's and don'ts
do not listen to that Crate Camaro dude. He is a cheatin bastard. He has a 427 stroker small block that he is claiming is a 300 hp crate motor. He started to do giant wheel stands after he put the cheater motor in.
Johnny U is offline   Reply With Quote
