Old 02-25-2010, 09:53 AM   #11
ss wannabee
Liked 7 Times in 7 Posts
Default Re: moron needs gm steel gasket #ends in 633
I was wondering if the racers in the "small-bore" community had used anything other than the GM #633, and the Cometic? I guess you could use the GM #711...but I think it's a bit thicker, and I don't think it fits the smaller engines as good as the 633...Not sure if you can get the 711 anymore? We're talking for early engines...the 265-283, and the 307. Maybe you could use a 305 head gasket? I think GM used steel shim on the very early 305's...and switched to composition? Any 305 "experts" know what those measure in thickness?
ss wannabee is offline   Reply With Quote
Old 02-25-2010, 10:13 PM   #12
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
I have used the 262/305 head gasket many times with my combination. It was old G.M. part # 14085906 & older part # 362690 and was also made by McCord. They were .016 thick & cross to currently still available # 10105115. The first two are steel shim while the third one has a coating on it & measures .025 thick so not a straight cross. As far as size I believe they are 3.910 compressed diameter but I will measure an old one and post that number later.
Allan
55 Chevy is offline   Reply With Quote
Old 02-25-2010, 10:39 PM   #13
Jack McCarthy
Liked 511 Times in 122 Posts
Talking Re: moron needs gm steel gasket #ends in 633
ok guys, thanks again to the forum for saving my butt... i now have enough head gaskets to insure i can race until my motor is worn out (like me)
thanks again to ray grice and bob wibright, old friends have old parts !
captain jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
