Old 02-28-2010, 02:40 PM   #11
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
Default Re: Electric fan ?
If I were you, I would do a Google search for "Custom Fan Shrouds" You never know what you might find there. I use the Google site quite often when looking for information.
Wade
Wade Mahaffey is offline   Reply With Quote
Old 02-28-2010, 05:41 PM   #12
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Wade
I was just yankin yer chain, I use searchs all the time and Im pretty good too.
One thing I can tell you for a fact as I was present, when you have a client who is the president of the "Great American Fruitcake Company" and he is computer illeterate, and youre in a boardroom with a projector (this was 1997) DONT let him try to answer the question "I wonder if Fruitcakes.com is taken ?"
The answer is yes....and its not a Christmas gift.
When looking for a BIG *** FAN, its always best to just try something like
http://www.bigassfans.com/
(Yes its a real site they make REALLY BIG Fans...)
Chris "drooze" Wertman is offline   Reply With Quote
Old 03-01-2010, 01:21 PM   #13
njk53
Greg, Aren't you going to use the stock fan shroud? That unit is specifically engineered for the car and will perform much better than any homemade or aftermarket unit. At the very least least it will get you close to the dimensions and specifications needed for good cooling performance.
Nelson Kowal
Stock 345
Old 03-01-2010, 01:41 PM   #14
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: Electric fan ?
stock shroud is MIA! so it's either go junkyarding or by new from somebody like year-one. I was just thinking that this is going to be @ the track a lot an electric would be better way to go...as in between rounds I can run the electric to cool the rad. I also need one big enough to cool the car if I run into town to get a pizza & beer .....3 miles each way.
Old 03-02-2010, 01:36 PM   #15
skooter
This setup will get you back and forth, pizza runs, + keep you going rounds!!
http://cgi.ebay.com/ebaymotors/ALUMI...Q5fCarQ5fParts
skooter is offline   Reply With Quote
Old 03-03-2010, 02:50 AM   #16
rick lester
Liked 4 Times in 1 Post
on my 88 suburban, i went to the junkyard and pulled a dual fan from a dodge stratus. used summit dual fan relay with 185 on/ 175 off thermostatic switch. with a HUGE big block aluminum radiator and the fans, i had to pull both relays to get any heat into motor for heater to work this winter. didn't even have to drill holes to mount fan to radiator, both had holes that lined up perfect with brackets that i made. actually strips of 1/4(?) inch aluminum, a few nuts and bolts, a couple of clips, and 2 strips of thin weatherstripping for cushion, and it works and looks great. 45 bucks for fan from the junkyard, and fans worked too. just take a tap measure to junkyard and go hunting. i drive the girlfriend nuts whenever i go to the junkyard, always dragging something home.
rick lester is offline   Reply With Quote
