Old 03-06-2010, 08:56 AM   #11
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Question Re: TCI Competition series TH350 Problems!
check the shifter cable,see if the adjustment is right.
btw did you have the low/rev sprage out,it can go in backwards.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 03-06-2010, 03:41 PM   #12
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Default Re: TCI Competition series TH350 Problems!
I agree,check the shifter linkage. On a TH 350,if you pull the lever back into low gear,and then a little further back it will allow fluid through a different passage and act like a trans brake. Lane
Lane Weber
Old 03-09-2010, 04:01 PM   #13
HotRodGMC68
the sprg was not messed with and went in as it was when it came out. I checked the shifter cable adjustment and it was right on per Hurst instructions.
When we tested the pressures I crawled under the truck, removed the shift cable and shifted it by hand at the transmission, letting it settle in the detents. no change
HotRodGMC68 is offline   Reply With Quote
