Old 03-08-2010, 09:24 PM   #1
twudarczyk
Default Rear wheel size and Tire size
I have a 78 Malibu wagon, that is going to be a little footbrake bracket car. I have a bolt-in 9 inch in it. I was wondering if anyone knew what size tire and wheel will fit without having to notch the frame.
Thanks,
Tyler
twudarczyk is offline   Reply With Quote
Old 03-09-2010, 01:39 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Smile Re: Rear wheel size and Tire size
30x9 radials fit..... How quick a car do ya have?
Old 03-09-2010, 03:31 PM   #3
Poke
Default Re: Rear wheel size and Tire size
With what rear springs???Also what size rim and backspacing???
Poke is offline   Reply With Quote
Old 03-09-2010, 11:49 PM   #4
twudarczyk
It will only run 11.90's at the quickest. I was thinking around maybe a 15x8 wheels with 4 1/2 backspace. Tire size I was hoping a 30x9, but if I have to go smaller I will.
Old 03-10-2010, 12:25 AM   #5
2021STK
Liked 17 Times in 14 Posts
I use 30x9 on a 15x10 with 5 inch BS on my 78 Malibu wagon but you need to check your housing width flange to flange measurement to be sure it's the same as stock.
Good luck,
Dave
2021STK is offline   Reply With Quote
Old 03-10-2010, 02:11 AM   #6
greg fulk
greg fulk's Avatar
Thumbs up Re: Rear wheel size and Tire size
my Cutlass (same chassis as your malibu) I run an 8" wheel with 4 1/2 back spacing....4 3/4 would work better. When I bought the car it had 10" wheels on it & they worked with wheel spacers.
