Liked 44 Times in 13 Posts
Forgive me if this is a silly question but I'm new to this class racing and I guess I'm not too shy to ask a silly question... How do you wire a 2-step in a stocker?? I have ran one for years in my SST car and wired it off the TB. But if I read the rules right a 2-step must be activated from either the clutch or brake pedal.... Is it done by break pressure or actually off the pedal itsself??? If its done by pressure is it the fronts or rears???? And what pressure do you use?? Thanks Mack
Mack Reeves 2377 STOCK & SUPER STOCK |
I my dad's car, we drilled the brake pedal on the lower right hand side and added the button to the pedal. His car has a large brake pedal so it made it easy to do however you just have to be careful when you depress the pedal at the top end not to hit the button.
Ronnie Dozier |
Liked 20 Times in 12 Posts
I have not put one on my car yet. But there is two different ways to mount the switch. Either on the brake pedal like stated above or a pressure switch T-ed into the front brake line. Either way I would put a switch on the shifter that is in series with the switch on the pedal, so that the button for the two step only works in low gear. That way when you are slowing down at the line or the turn off you do not activate the two step again. Mack by the way what track is your home track? SGMP?
Robert Last edited by Robert Simpson; 03-17-2010 at 11:19 AM. Reason: Add comment |
Some guys use a brake pressure activated switch. One SS car I know of had a 1000 psi switch. Didn't have to worry about activating it at the finish line that way. You'd never be on the brakes that hard and if you were, the 2 step activating would be the least of your problems.
I've also seen a couple guys use a microswitch mounted on the shifter that disables the 2-step when the 1-2 shift is made.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
#5 | |
I understand about the switch on the shifter for only 1st gear but what if you have the auto shift valve body and you start with your shifter in 3rd and just the valve body does the shifting??
#6 | |
We do not use them but we have seen some stock guys just put a switch on two step and activate it by hand in high gear. That
would work with stock shifter. Just do not forget to turn it off. Most of guys I have seen use ford brake light switch. Guessing more like 10-20 psi. John Irving |
#8 | |
Im "thinking" what would be the most FUN is to hook one to a "key remote" and pass it around the pits, with a BIG Label DONT PRESS THIS BUTTON, and see how long it takes before youre up ended in the staging lanes. Kinda like my buddy who washed the dog put its electric collar in his shorts then his wife asked him to go buy milk....oooooooouuuuuucccchh. Im setting mine up on the brake pedal, Ive been told why not to, but thats Ok, Ill live with it, Ive got a switch I can adjust the throw on so, I can set it for "touch" Our 2 step will also actuate on a "circuit open" so....thats one of the reasons why. Now for the burnout limiter to keep us coming out of the water at over 8k ![]() ![]() ![]()
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
Liked 216 Times in 77 Posts
Mine is above the pedal and what I do is I pump the pedal up to the pressure I want then bump into the beams and roll my toes up onto the switch to activate the 2 step. I use a B&M trans brake switch with the big red button. To mount the button I bolted a piece of 2X2 angle aluminum to the pedal and drilled a hole in it for the button. Its up high enough that you can still hit the brakes without worry of hitting the button at the finish line but not so high that its hard to reach with your toes when staging. If you PM me your email I will try and send you a couple of pics to get a better idea of how I did it if you want. You can share them here if you want too I just have not got the picture posting deal figured out yet.
