#21 |
Liked 20 Times in 14 Posts
I know it's it's a DUMB ? but both Greg Hill and Evan Smith refered to the 1.5 factor. Can someone answer it please.
-------------------------------------------------------------------------------- Two people now have mentioned the 1.5hp to factory rating to be above average. An engine that averages 500HP and has a top number of, say, 540HP is the 1.5 # used on the 500# or the 540#????? |
#22 |
Liked 1,880 Times in 422 Posts
It's the NHRA rated HP. So an engine rated at 350HP by NHRA needs to make 525HP.
Alan Roehrich 212A G/S |
#23 |
But is the 525 in your example an average accross a range or just a top number??
ps thanks in advance |
#24 |
That would be the peak HP number.
#25 |
Thats what I was looking for.
Thanks again |
#26 |
Liked 653 Times in 89 Posts
Bruce the non Super CJ makes way less then 800hp to the rear wheels. What is you point.
Charley Downing 3548 STK |
#27 |
It's interesting how people throw "torque" around.
HP=Torque x RPM / 5252 So HP is nothing other than a mathematical derivative of torque. It's been a long time since I've seen a normally aspirated car in Stock Eliminator (especially when you get above L,M, or N) run less than about 5500 RPM stall, or leave at less than 5500 if it is a stick car. So, 5500 RPM is above the point at which torque is a higher number than HP, as torque and HP will ALWAYS be equal at 5252 RPM, and torque will ALWAYS be greater than HP below 5252 RPM. That also means HP will ALWAYS be greater than torque above 5252 RPM. In this modern era of efficient high stall converters that yield in excess of 2.0:1 torque multiplication at their flash stall speed, and trick clutches, when someone tells you that it is necessary to have "torque" when "moving a heavy Stock Eliminator car", remember that in order to make HP, you must have torque to begin with, since torque is the actual force, and HP is merely a mathematical derivative of the force called torque. Two engines that have "X" HP at 6000 RPM have the same exact amount of torque at 6000 RPM, regardless of how many cubic inches they displace, what their bore/stroke ratio is, or what their rod/stroke ratio is.
#28 | |
Liked 1,439 Times in 301 Posts
Do the OEM numbers come from the max that the combo makes or can the Manufacturers pick the RPM they rate it at? You make this sound like they flogged it out for a number that WE as racers would chase. I would think that the Manufacturers would play the same game they always did in the past with this number.Then they could low ball the rpm pulse width, timing, etc. if they wanted to. When they are "certified" does the certification look into this also? What if your 300hp deal makes 400 at 1000 rpm more? Does the certification process include the sniff test on the dyno? Tim, you seem to look at this closer than I have, do you know?
James Schaechter 3163 STK Last edited by james schaechter; 03-27-2010 at 02:12 PM. |
#29 |
Liked 444 Times in 145 Posts
The point is you need to keep up with these threads if you want to brow beat folks. Read some of the old threads on the CJ's and you may learn something.
Bruce Noland 1788 STK |
#30 |
Liked 11 Times in 4 Posts
Bruce - you find me a dyno sheet from a Cobra Jet Stocker that makes over 800HP and I'll issue a formal apology to anyone wrongly accused of being a moron. Until then my statements stand.
Tim Kish 3032 SS/GS |
