Old 04-04-2010, 01:06 PM   #1
FED 387
Liked 333 Times in 180 Posts
Question Any Ford dealer techs out there????
Any body work at a Ford dealership???? Need a someone to look up a TSB--technical service bulletin--- for me please--NEED THE TSB ###--- Vehicle is a -2000 F250 Super Duty with the 7.3 Powerstroke Diesel ONLY 97000 miles---supposedly a TSB refering to the bolt s either loosening or backing out completely on the turbocharger housing---when this happens the turbo fins get destroyed because the whole assemply is not containing the impeller correctly----- Need the number please and I'm also trying to find out if MAYBE Ford will cover this ---Seems to occur rather frequently not all that unheard of according to several repair shops I talked to--- Just trying to save $700-1000 dollars if I can get them to fix it under warranty----Thanx Comp 387
Old 04-04-2010, 01:43 PM   #2
Floyd Gomez
Floyd Gomez's Avatar
Default Re: Any Ford dealer techs out there????
TSB #14032 -- SOME VEHICLES WITH 7.3L DIT ENGINES MAY EXHIBIT LOOSE TURBO BOLTS ON THE TURBO HOUSING. TYPICAL SYMPTOMS OF LOOSE BOLTS INCLUDE LACK OF POWER AND AN OIL LEAK. *TT (NHTSA ID #620294, MARCH 01 2001)
Floyd Gomez is offline   Reply With Quote
Old 04-04-2010, 01:45 PM   #3
Floyd Gomez
The bulletin was released in 2001 and Ford payed for the fix until 1/2003. If you did not recieve a recall or TSB and were the original owner you may be able to get them to help but I doubt it.
Old 04-04-2010, 01:45 PM   #4
mtkawboy
Liked 54 Times in 18 Posts
http://www.ford-trucks.com/tsb/tsb.php/m-FORD/y-2000 look on here, never mind, double post
mtkawboy is offline   Reply With Quote
Old 04-04-2010, 03:06 PM   #5
art leong
Ask this question over on Diesel truck forums Their are a lot of very knowlegeable Ford diesel people there
When ever I need to know something about my truck thats where I go.
Art Leong 2095 SS
Old 04-04-2010, 04:52 PM   #6
FED 387
thanx guys will check into it on Mon---Comp 387
