#11 |
S/ST 1988 I thought had a great idea !!!!! Kinda like Sunday, Sunday, Sunday S/Gas , S/Gas, S/Gas...............
#12 |
Can't do Super Gas...too many family and friends there. I need a class where I can't lose on Saturdays...Super Street sounds good to me!
#13 |
you need to go 7.40 7.45 in the eighth to be 10.90 in the quarter ,thats what i had to run in my chevelle that went 8.95.
jj h/r 1399 s/r 1399 ![]() |
#14 |
Dem's sounds like fightin' words to me!
Jason Oldfield S/G & S/St 1838 |
#15 |
Liked 3,244 Times in 986 Posts
Easy Jason, schedule shows first round of S/ST on Sunday morning...
#16 |
#17 | |
![]() my junk runs about the same Timer 1- .2 Timer 2- 3.8 Shift @.7 stop rpm 4300 go from there and just something to ponder, Super Street is just as tough as Super gas even though it is "entry level" ![]() |
#18 |
In a local 10.90 series I ran my Super Gas corvette in 10.90 trim just for fun. The car all out ran 8.98 150 MPH (5.72 at 119 mph in the 1/8th)
To go 10.90 I set up my stop to come on at .050, car shifted into high gear at .700 and was on the stop for 3.600 seconds. My stop RPM was 4300. The run looked like this: 1.727 60' 5.146 330' 7.464 660 ET 110.38 660 MPH 9.340 1000' 10.894 1/4 ET 145.74 MPH This was a combo I used in cold temperatures (53 degrees and 610 feet density altitude) I have three passes 7.450= 10.884 7.464=10.894 and 7.427=10.876 Hope this helps Andrew |
#19 |
i use to run my malibu on the stop at 3700-3800 and to run 10.90 i was 7.47 to 7.50 in the 1/8th. and that was 8.91 wide open. so if you are running 8.6's or 8.7's i would try to get near 7.57 to 7.62 in the 1/8th, then you can ballpark when you get there. but as long as you have your ratio, you will be fine.
#20 |
