Old 04-05-2010, 02:32 PM   #11
Bob Verwold
Bob Verwold's Avatar
Default Re: 10.90 1/8 Mile Number Help...
S/ST 1988 I thought had a great idea !!!!! Kinda like Sunday, Sunday, Sunday S/Gas , S/Gas, S/Gas...............
Bob Verwold is offline   Reply With Quote
Old 04-05-2010, 02:41 PM   #12
TruRacrMotorsports
Can't do Super Gas...too many family and friends there. I need a class where I can't lose on Saturdays...Super Street sounds good to me!
TruRacrMotorsports is offline   Reply With Quote
Old 04-05-2010, 06:12 PM   #13
JJ3159
JJ3159's Avatar
you need to go 7.40 7.45 in the eighth to be 10.90 in the quarter ,thats what i had to run in my chevelle that went 8.95.
jj h/r 1399 s/r 1399 s/g 1399
JJ3159 is offline   Reply With Quote
Old 04-06-2010, 10:30 AM   #14
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
Dem's sounds like fightin' words to me!
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
Old 04-06-2010, 11:58 AM   #15
jmcarter
jmcarter's Avatar
Liked 3,240 Times in 986 Posts
Easy Jason, schedule shows first round of S/ST on Sunday morning...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-06-2010, 12:02 PM   #16
Bob Verwold
Saturday is just 1 time run at about 8:30 am so he's good......BUT, Sunday is a different story.........He He
Old 04-06-2010, 12:07 PM   #17
Dave Polichena
pretty strong words there boy
my junk runs about the same
Timer 1- .2
Timer 2- 3.8
Shift @.7
stop rpm 4300
go from there and just something to ponder, Super Street is just as tough as Super gas even though it is "entry level"
Dave Polichena is offline   Reply With Quote
Old 04-06-2010, 01:45 PM   #18
cujo3116
cujo3116's Avatar
In a local 10.90 series I ran my Super Gas corvette in 10.90 trim just for fun. The car all out ran 8.98 150 MPH (5.72 at 119 mph in the 1/8th)
To go 10.90 I set up my stop to come on at .050, car shifted into high gear at .700 and was on the stop for 3.600 seconds. My stop RPM was 4300.
The run looked like this:
1.727 60'
5.146 330'
7.464 660 ET
110.38 660 MPH
9.340 1000'
10.894 1/4 ET
145.74 MPH
This was a combo I used in cold temperatures (53 degrees and 610 feet density altitude) I have three passes 7.450= 10.884 7.464=10.894 and 7.427=10.876
Hope this helps
Andrew
cujo3116 is offline   Reply With Quote
Old 04-06-2010, 02:25 PM   #19
Scotty Phillips
Scotty Phillips's Avatar
i use to run my malibu on the stop at 3700-3800 and to run 10.90 i was 7.47 to 7.50 in the 1/8th. and that was 8.91 wide open. so if you are running 8.6's or 8.7's i would try to get near 7.57 to 7.62 in the 1/8th, then you can ballpark when you get there. but as long as you have your ratio, you will be fine.
Scotty Phillips is offline   Reply With Quote
Old 04-06-2010, 02:39 PM   #20
Bob Verwold
An after thought, you do know S/ST weight is 2800 with driver.
And they run us over the scales from time to time.
