Old 04-07-2010, 09:50 PM   #11
Just Observing
Default Re: Jerico tranmission
Originally Posted by drooze View Post
How are guys shifting these ? Cant be by hand ? Or is it ? And clutch ? Are we talking a pedal, like as in rowing a 4 gear ? I cant believe thats the way its done....is it ?
This video will show you alot. Watch Jim in action and pay close attention to his nano-second clutch work on shifts. wink,wink.
Just Observing is offline   Reply With Quote
Old 04-07-2010, 10:04 PM   #12
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Thanks VERY informative
Man his clutch leg moved so fast the video didnt even catch it
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 04-07-2010, 10:08 PM   #13
Jeff Lee
Jeff Lee's Avatar
It's all about strength and efficiency, that's why you don't see OEM style trans in S/SS classes. Remember, at one time a quick trip to the wrecking yard and $75 - $125 bought you an OEM 4-speed with a 2.20 low gear. Those days are gone.
And let's say you have an inventory of 'em and you want to race with one. First you have to come up with a gear spread that starts with a 2.95 or so low and a 1.20-1.40 third that doesn't drop a ton of RPM on the splits. Almost impossible.
And whatever ratio's you run, you have to modify the heck out of it for strength.
The Viper trans is a long way away from taking a 500 HP engine and a solid hook on a 9" slick although the press release from today could ad some strength. But I seriously doubt it is enough...
A Jerico is around $2800 brand new with gears of your choice, ready to race. Is that too much? If so, let's talk about an auto trans for dedicated S/SS use with a convertor or two (or three or four..)
Press release:
Posted - 04/07/2010 : 8:16:22 PM
Attention Street/Strip Enthusiasts
G-Force Transmissions and Long Shifters is pleased to announce some exciting new products to their already vast transmission and shifter lineup. With today's modern street cars it has become relatively easy to bolt on more than enough power to surpass the factory torque/hp ratings of virtually any OEM-style transmission. With this in mind,
G-Force has come up with a wide array of upgrade kits for most of the popular domestic OEM transmissions available today. The kits allow for factory-style installations to eliminate the need for crude and expensive modifications to the tunnels and/or crossmembers on most cars.
New Product Spring 2010
3650 Kit Available in Late Spring 2010
Already available are the T5 and T56 upgrade kits for the Mustangs, Camaros, Vipers, and a host of other vehicles that utilize one of these two transmissions. With thousands of these kits already sold, G-Force has come up with another exceptionally durable gear kit, only this one is for the 3650 transmission that comes in the 2001 to 2010 V8 Mustangs. This is the first aftermarket gear kit offered for this transmission and we've taken the unprecedented step of offering this kit with precision ground gears to help eliminate some of the NVH (Noise, Vibration, and Harshness) associated with inferior aftermarket gear kits. The gear design is from our proven T56 combination so there is already a vast database of testing experience with this particular design. A 2.90 1st gear is standard on these kits as is a .58 overdrive gear to accommodate for the typically steeper rear gear that most cars run for street/strip applications. Great for launches and even better that stock fuel mileage in most applications. This transmission can also be retrofitted into virtually any other vehicle with the addition of the special adapter that we make for "early-style" installations.
For more information, please give G-Force a call at 717-202-8367, M-F 7:30 to 4:00 EST.
Product Highlight
GF5R
GF5R
Reconditioned 5-Speed GF5R's available
The GF5R 5-speed transmission from G-Force is still one of the most durable and versatile transmissions available today. With both clutch-assisted and clutchless configurations available, the GF5R can be utilized in most any class or form of racing. We are now offering remanufactured GF5R's that have been traded to us at tremendous savings over new units. These transmissions have been gone through extensively and have been freshened up with all necessary parts. They typically range in price from $4,000 to $5,000 depending on model and application. Both clutch-assisted and clutchless models are available. We will do everything we can to tailor the ratios to suit your needs wherever possible. For more information, contact Jason or Bubba at
G-Force at 717-202-8367, M-F 7:30-4:00 EST.
SPECIAL PRICING
4-Speed G101A/GF4A Special Pricing
G101For a limited time G-Force will be offering our G101A and GF4A 4-speed transmissions at special pricing. Now you can save anywhere from $100 to $400 off the regular price depending on application and model. For even greater savings, consider one of our reconditioned units that are built from high-end circle track take-out parts and in most cases are built with new cases, tailhousings, and shifters. These units are from our circle track rental program and/or trade in parts from top teams. The parts are like new, except for the price. These remanufactured transmissions typically range in price from $2,500 to $3,500 depending on model and application.
For more information, contact Bubba at 717-202-8367.
Shop Tour
No Compromise in Quality
Shop Tour
Long's Machine & Tool, parent company of
G-Force and Long's Shifters, has been producing high performance transmissions and shifters used by many of today's top Nextel Cup and NHRA racers for more than 14 years. The company's products are engineered using the most up-to-date CNC machining technology and computerized inspection equipment to optimize accuracy and repeatability.
Thanks for Your Business
The G-Force Transmissions Staff-
Jeff Lee 7494 D/S '70 AMX
Old 04-07-2010, 10:34 PM   #14
Cool on the press release, but no, I could get 1500 out of the Viper tranny on Ebay and put that twoard a new trans if we go that route.
Put lipstick on a pig.........
I know guys are modifying them to handle 1500+ hp, but youre right thats not hard lauch, and with that it would probably become "lunch" it was curiosity well....because I dont have a use for it...lol
No its a hell of a lot cheaper a grand a converter 4-5k for a "right" trans with all the trick stuff.....
Old 04-08-2010, 12:43 AM   #15
hemidup
Thanks for the replies. Worked late tonite on the DP and all the while kept thinking about running the Jerico. We already have a Lakewood bell housing but would need a custom flywheel and linkage assembly and hopefully not have to touch the trans tunnel. Some more things to think about, but it looks like this could be the route we go.
Jerry Williams
NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's.
hemidup is offline   Reply With Quote
Old 04-08-2010, 10:05 AM   #16
Harry 6674
If you decide to go that route give Advanced Clutch a call they have it covered.
Harry 6674 is offline   Reply With Quote
Old 04-08-2010, 10:16 AM   #17
Jerry, Called GForce today, theyve got some "used" refurbed units that are "nascar" 4 speed "clutch assisted" units for 2700 with shifter your choice Zgate or H
Apparently something changed in Nascar so they got all their leases back but its the same as the Drag, they said they can do any ratio combo on these.
Sounds like a good deal.....(only on 4's)
Can be shifted without a clutch just has momentary "neutral" while it does as opposed to the twin shaft delio....that always transmits power but that is called a clutchless, technically it wouldnt be legal from the way I read the rules, but the "clutch assisted" would be ? Is this "correct" ?
Just some info for all...
Old 04-08-2010, 10:41 AM   #18
EdgarTurbo
I'm assuming that the liberty transmission is accepted too, right???
EdgarTurbo is offline   Reply With Quote
Old 04-08-2010, 11:59 AM   #19
Bill Belden
Bill Belden's Avatar
Jerico and Advanced Clutch, only way to go
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 04-08-2010, 12:50 PM   #20
tj310
Liberty web site says twin countershaft "delio" legal for SS . Twin countershaft does not equal clutchless. Split or individual gear engage disengage = clutchless..IMHO..Thanx Trevor
