Old 04-12-2010, 11:07 PM   #11
Grant Eldridge
Grant Eldridge's Avatar
Default Re: M200 breakage
Dave,
I had several case failures with my TH-200, fortunately caught before catastrophe struck. I tried to buy a brace from McClay, but he only supports his own transmission customers, or at least did at that time. I built my own brace connecting the two "eyes" on the passenger side of the trans with 1/2" thick by about 1" wide aluminum. I tried to upload a photo but the file is too big. Email me at grant4060@yahoo.com if you'd like a few photos. I also bought an aluminum deep pan from Turbo-Action to act as a girdle and give more strength to the case. I run this behind a big block stocker, 3570 lbs. with best of 1.41 60' and since the changes have had no further troubles. The transmission is a reverse pattern unit built by Jim Mantle, who is the greatest guy to deal with, and his units have always performed perfectly. Ditto on using the stock rear mount, also would suggest the left front torque strap from earlier posts. Make sure there is enough spline depth in your driveshaft yolk so that it cannot bottom out when the car launches and the rear end pushes it ahead. Hope this helps,
Grant
Grant Eldridge is offline   Reply With Quote
Old 04-12-2010, 11:20 PM   #12
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Bill, it was smooth with no shake. The driveshaft was perfect length for sure, u-joints were good with fresh grease. The tailshaft looks ok, other than the seal has a slight bend when the yolk came flying out. The shaft looked good with no dents or any other signs of damage. Not touching the loop either. Could the shaft just have failed? seems rare to me that a shaft would twist and break like that.
It is Peter's old car, its not going to be back together for Boise now, all plans have changed, hoping to be ready for Mission.
also guys, I am using solid motor mounts along with the poly trans mount. so strap is not gonna do anything. Are the solid mounts not a good idea?
Grant,
I will e-mail you, thanks
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 04-12-2010, 11:21 PM   #13
Grant Eldridge
Dave, I'll try to do these photos again....
Grant
P.S. No one will confuse these with the McClay brace, but so far so good...lol
Name:	TH 200 Brace 2 small.JPG
ID:	2856   Click image for larger version
Name:	TH 200 Brace small.JPG
Old 04-13-2010, 08:17 AM   #14
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
call frank lupo or shawn at dynamic he can get you a professionally made brace
jim powers is offline   Reply With Quote
Old 04-13-2010, 11:19 AM   #15
Todd Hoven
Guest
Posts: n/a
Leon Mirainian also builds a Tubular brace with heim joints. Great looking piece. I have had one on all of my metrics since I've been racing them. he also builds a great 200...
Old 04-13-2010, 11:25 AM   #16
Dave Jung
Dave Jung's Avatar
Todd, do you have a number for Leon?
thanks to all the guys who have replied. I really appreciate the help.
Dave
6535 stk
81 Malibu K/SA
Old 04-13-2010, 11:53 AM   #17
Ken Haase
I raced an Olds with a 455/th400 and put many passes on the stock driveshaft that had a rubber slip connection close to the rear u-joint. Genius that I am, I figured that a solid shaft would be this huge improvement. On the first pass at 100+ it roused me out of my slumber by reconfiguring the floor contours. Found half of the shaft and the slip yoke was still in the back of the trans. The bellhousing was busted almost all the way around, plus lots more damage.
So, my wager would be the driveshaft failed for whatever reason. I don't think TH 400's have a reputation for weak bellhousings.
BTW, for Olds freaks, that was a "W" code tagged trans.
Ken Haase is offline   Reply With Quote
Old 04-13-2010, 02:15 PM   #18
Greg Barsamian
Liked 427 Times in 97 Posts
Leon Miranian's
Turbo-Flite Racing Transmissions
(443) 995-3945
Old 04-13-2010, 05:13 PM   #19
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Originally Posted by Bill Edgeworth View Post
Thats why McClays come with a case brace.
I'm not sure if he will sell you one if you are not a trans customer.
How hard did it leave?
We use McClay, with a rubber mount also. I might add that McClay not only uses
a brace but he adds a gusset or two on the case. The failure you described is the
common 200 breakage area, but without the driveshaft failure thats a new one.
If you did have everything mounted solid its possible you might have some pinion
angle issues that added to the driveshaft failure. just a thought..
Bob Aceves
#746 E/SA
A&M motorsports
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
