Old 04-17-2010, 07:00 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Wheel tubs in Super Stock
I left a message with NHRA tech but their at the races right now. I've been told the rule regarding wheel tubs (must be steel, same gauge as factory) has been modified to allow the use of aluminum tubs. But I can't find reference to that in the rule book. Is aluminum allowed (or carbon fiber), and if so, where is it noted?
Another question. Is a full length one piece tub allowed in a car that came equipped with a trunk (unlike the 'vettes)? I've heard of at least one SS 1st gen Camaro with this feature. I like the idea of a carbon fiber tub as there would be no rock dents like aluminum and a full one-piece tub offers more room on the underside to work around. I can't imagine carbon fiber is any lighter than aluminum.
Jeff Lee 7494 D/S '70 AMX
Old 04-18-2010, 01:19 AM   #2
RPinoski1
Default Re: Wheel tubs in Super Stock
Must be steel
aluminum ok for back piece and package tray ie firewall to trunk area.
For SS must have original floor between frame rails.
For GT original floor not required between frame rails.
Material must be same thickness as original
RPinoski1 is offline   Reply With Quote
Old 04-18-2010, 10:05 AM   #3
Chad Rhodes
i wonder if you'd put steel tubs in a vette............
Chad Rhodes 2113 I/SA
Old 04-18-2010, 03:14 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Chad,
I wouldn't!
Adger Smith (Former SS)
Old 04-19-2010, 09:44 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
We did hand made fiberglass tubs in our 'Vette back in '89 with no objections.
Old 04-19-2010, 04:12 PM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Jeff, I've seen several cars done this way in SS. ...It really makes sense in a car like the AMX because of the short wheelbase and no room behind the seat area..........The tubs were made big enough to cover the 4 -link . .....Tom
Old 04-19-2010, 07:23 PM   #7
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
In Stock and Super/Stock the tubs and floor modifications must be solid welded if the car is steel. Aluminum, Carbon Fiber would need to be bolted and or riveted and that is not allowed. I was told by a very senior NHRA offical that I would have to use steel for a removable trans tunnel (in S/S your allowed 6 Sq. Ft. removable) in a fiberglass car (60 Corvette). I think the Corvette stuff of todays racing is kinda uncharted territory. There aren't that many cars out there. And the average offical just does'nt know that much about them.
Here is my answer to tubs in a Corvette
Wade Mahaffey is offline   Reply With Quote
Old 04-19-2010, 07:37 PM   #8
Jeff Kempton
Jeff Kempton's Avatar
Liked 67 Times in 31 Posts
Originally Posted by RPinoski1 View Post
Must be steel............Material must be same thickness as original
If NHRA held you to this wording, wouldn't that mean that steel tubs installed in a Corvette would need to be 1/4" thick at least, to match the stock fiberglass wheelwell thickness? Yikes!
Wade, I have been on your site and following your Corvette build, and you exhibit great workmanship. Those wheel tubs are very nicely done. When we put tubs in a '57 Corvette many years ago we used sectioned fuel drums as molds......and the end result looked it too! Not one of our prouder achievements......
Jeff Kempton is offline   Reply With Quote
Old 04-19-2010, 07:51 PM   #9
W J
Thumbs up Re: Wheel tubs in Super Stock
Wade.....1st class craftsmanship on that '60 Vette of yours......hope it hits the track this season. WJ
Old 11-20-2011, 10:07 PM   #10
Darrin Christen
Darrin Christen's Avatar
I know this is an old post, but do the steel wheel tubs have to be welded in or can they be riveted?
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
