Old 04-18-2010, 08:38 AM   #1
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default clutch recomendations?
290/3.44 1 st gear 4speed american, alum f'wheel,4.57 gears,8.5 slicks, around 3200lbs w/ me in it
anybody recommend a single disc+pp?
flywheel is drilled for borg&beck or diaphram.
USED to be a long style that was made with b&b bolt pattern but if there is now, i ain't finding it...
Old 04-18-2010, 09:10 AM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: clutch recomendations?
you will have to do some research on what will fit ,,,for that ,,,is the trans a amc t-10 or a gm t-10(info from previous post),,thats a real low first gear for that trans ,,i would say if your presure plate is drilled for a borg & beck check out a ram adjustable plate and a sintered iron disc ,,more than likely you may not need a ton of base presure ,,you will have to tread lightly if you are using stock type transmissions Gmonde
Old 04-18-2010, 03:55 PM   #3
Jeff Lee
Jeff Lee's Avatar
Originally Posted by tomslik View Post
you buyin'?
2500 bucks for a 14 sec car clutch seems a bit overkill
Then please, be specific with your questions. If you can't or won't afford the best parts available for the quickest ET possible, then say so.
Autozone or Checker Auto has rebuilt clutches that are more affordable. They may not last, they probably aren't fast, but it will get you through the pits.
Jeff Lee 7494 D/S '70 AMX
Old 04-18-2010, 05:02 PM   #4
Tom keedle
Tom keedle's Avatar
don't be a dick and I won't be...
thought i WAS specific, what more do you want to know?
i'm not gonna be running in the upper classes of stock OR superstock nor do i have stock in ACT clutches
gmonde is on the same plane as me, i think or at least is more realistic.
last i checked,ACT didn't have anything i could use (AMC)but i could be wrong...
besides, i could run a LUK if it had the sfi sticker on it...
maybe impact has a few they'd sell me....
btw,seems like the only way i'd have to worry about a heads-up race is if i'd build 2 cars...
way too many autos out there..
Old 04-18-2010, 06:53 PM   #5
Tom keedle
Tom keedle's Avatar
Originally Posted by montys 55 View Post
tom
i recomend ram. i had a long adj. plate and a hays wheel that i sent them and they set it up with a sintered iron disc to sfi spec. it was a little over 500 complete.
hope this helps
how do you like the iron plate?
THAT's what i'm trying to decide on anyway...
that and how many "pads"...
i AM leaning toward the B&B Ram adjustable (think it's like 2200# to 2500#)...
Old 04-18-2010, 06:55 PM   #6
gmonde
gmonde's Avatar
no pads!!!!!! solid disc you need to have slipage Gmonde
Old 04-18-2010, 08:58 PM   #7
Tom keedle
Tom keedle's Avatar
makes sense, what kinda lining?
sintered iron,kevlar, organic (whatever THAT is )?
Old 04-19-2010, 06:59 AM   #8
randy wilson
Liked 22 Times in 22 Posts
depends on whether you are plannining on using the clutch or not between gears. sintered iron if not clutching, rag if using the clutch.
don,t have one
Old 04-19-2010, 02:33 PM   #9
Tom keedle
Tom keedle's Avatar
well, gee, gotta use the clutch according to NHRA.....
and for the time being,this is a stone stock super t-10...
rag it is, then...
thanks for the advise, guys!
Old 04-20-2010, 05:58 AM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
tomslick,
You can use sintered iron and use clutch on gear changes.I would redrill flywheel for long style pressure plate the ram is most economical can get adjustable long style and sintered iron disc around 700.00.(new)You'll need lower base pressure though probaly 1200# and lower.Anyone that has bridgeport style mill and knows how to use it can redrill flywheel for long style,I have even done it on vavle/guide seat machine before.
On low power car clutch is still important because if it does'nt have controlled slippage it will bog on launch and or gear changes or both.
Mike Taylor 3601
