#11 |
Liked 22 Times in 22 Posts
mile is right, you can use the iron clutch if using the clutch, i just meant the rag was quicker for us driving conventionally. the sintered iron will have the very least pedal pressure.
don,t have one |
#12 | |
Liked 8 Times in 7 Posts
btw, the least pressure adjustable plate i can find in a B&B is 2200lbs... |
#13 |
Liked 282 Times in 78 Posts
Call Tim Hyatt at Hyatt Racing Services at 440-254-1311. He will get you fixed up. You also need a low base pressure and that is where the low pedal pressure comes from. The clutch is what is going to save or kill your drivetrain. The 2200# is most likely an on the shelf item. Tim will set you up with something more user friendly, and can modify your flywheel too.
Sean
#14 |
Liked 56 Times in 29 Posts
If you need to save money, Peter at South Bend clutch (800-988-4345) has experience with clutches for drag cars as well as diesel tow vehicles. His diesel stuff is state of the art. His street and drag clutches are conventional and not ideal for drags, but cost maybe 20% as much and he can tailor something to your car that will be pretty good, much better than off the shelf parts house stuff.
#15 |
Liked 321 Times in 109 Posts
Disc material won't affect pedal pressure but material of disc will determine what base pressure you can run which affects pedal pressure.Sintered iron is most reliable forgiving consistent and don't cost much more if anymore but will out last everything else.I have ran a single disc in 600 hp 2900# car with base on pressure plate down as low as 300#s I was leaving line at 9600 so centrifical assisted some but did'nt have any weights added lower rpm car you could'nt get that low on pressure.BTW when you get low pressure setup make sure you use extra heavy duty return spring slightly smaller than hood hinge spring because pressure plate won't push back enough by it self with normal return spring
Mike Taylor3601 |
#16 |
Tim or Rob can point you in the right direction, but for a budget set up that never ceases to amaze me try a centerforce. A customer of mine runs one in a 450hp/2900lb street strip car with a Toploader and can't kill it (he's tried), 60's in the 1.450- 460 all day. zero maintenance, changes the disc once in a while, if your not turning big RPM might be worth a look.
Carlo |
#17 |
Liked 419 Times in 85 Posts
I have several slow V-8 stick cars. If the clutch does not slip you better have a heavy flywheel because the second the clutch grabs it will about shut the motor off. I will be willing to help you. its fun to see slower stick cars
